Previous in Forum: increase head of the axial flow pump   Next in Forum: bikes.
hydro test
07/23/2007 4:33 AM
hello gents, i have encountered during hydrotest in stainless steel line,when i have injected water into the line at that time i found ph value of water was 10.4 but after the hydro test when i have checked ph value found 11.7 the interval of 1st reading to second reading approx. 6 hrs and atmospheric temp.was 48 deg cel. can any body tell me this happens due to atmospheric tempr.or somethng else.
Good Answers: 97
Re: hydro test
07/23/2007 5:17 AM
With a phy of 10.4 you would have a high concentration of alkaline compounds in the water. A temperature of 48 deg in an arid area a lot of water could evaporate leaving a higher ph.
The following is said because of experience with dolomitic water and not as a chemical expert. The alternative possibility must be considered.
The alkalinity of the water caused by CaCO3 and MgCO3 does not show in a normal ph test. It has been noticed that the ph of water rises over time exceeding the possible rise due to concentration. It could be attributed either or both. Reaction with air loosing CO2 or O2, or the precipitation of a calcium film on the container.
In both cases I suspect the excessive alkalinity to be converted to something else having an effect on the ph reading.
It would be wise to inspect the whetted stainless steel for signs of deposits.
Good Answers: 19
Re: hydro test
07/24/2007 11:34 AM
A remote possibility, but were the lines cleaned and flushed before test? What chemicals were used for cleaning and flushing? And as Hendrik points out, at what temperature?
You might be interested in: pH Electrodes, pH Transmitters, Hydro Turbines
