Previous in Forum: Drilled Holes in a Sphere   Next in Forum: Reducer
10 comments
Reducing Tee Description
10/20/2015 12:41 AM
In a reducing tee, it is mentioned as SA and NNLT. What does it mean ?
Good Answers: 225
Re: Reducing Tee Description
10/20/2015 3:30 AM
SA probably refers to the ASME pipe grading such as ASME SA 234 or 815 etc.
I have never come across the NNLT, but often in specifications the letters NLT will appear, which generally means "Not Lighter Than" and allows you a degree of latitude in your selection provided the item is of no less quality and strength.
Good Answers: 76
10/20/2015 5:12 PM
Please restate 'exactly' how it is referenced, in its entirety.
Good Answers: 76
10/20/2015 8:20 PM
Baring any additional information thus far, SA could be related to Swedish Surface Prep Standards:
http://www.blastal.com/images/SSPC_Chart.pdf
Does that make sense based on your usage/source?
10/20/2015 6:08 PM
In another forum thread SA was determined to mean "Same As" indicating that the rating of the fitting(s) should be the same as that of the connecting pipes' schedule.
Hobbies - DIY Welding - Still a New Member
10/21/2015 2:47 AM
Wild guess at NNLT, Nominal Size 1, Nominal Size 2, Length, Thickness
Good Answers: 97
10/21/2015 7:05 AM
It may refer to the sizes, NNLT would then mean that the outlet and the branch is normal and the other one is large.
Good Answers: 122
10/21/2015 10:31 AM
Manufacturers are allowed to put any characters they need/want on their products.
The SA and NNLT are not standard ratings so they could have many different meanings depending on the particular manufacturer's coding.
SA could be South America (Country of origin)
NNLT could be their company standard for threading procedure used.
I suggest you contact the manufacturer and ask them what the characters mean if you want anything other than a WAG.
Good Answers: 26
10/21/2015 2:03 PM
In my early days at Boeing just as computers had evolved the prints would state "PORM". The suppliers would call me up and ask what the hell that ment. Well we could not put +/- on the prints , at that time, so PORM ment plus or minus.
10/21/2015 11:31 PM
Never saw "NNLT" but is it possible that the term has some reference to a nuclear plant piping spec?
10/21/2015 11:59 PM
"SA" is the abbreviation for ASME specification.
"NNLT" doesn't seem to be a standard abbreviation or terminology for Pipe Fitting specification. You need to give more details on this.
BubbleRob (1); Casper71 (1); Hendrik (1); JAlberts (1); JavaHead (2); SHOCKHISCAN (1); spades (1); srijitpv (1); texasron (1)
