Previous in Forum: Calculation of WFT from DFT   Next in Forum: Angle of Twist and Power to Shaft Questions
PH Level Of Treatment Water
10/26/2015 6:59 AM
Dear All,
I would like to know, how should about PH- Level of Drain water or Treatment water.
e.g, Drain out water discharge form any build to any ditch or river. So this water should be clean as any rate. So how will be define rate to waste water for discharge?
Where code can I approach and refer?
Best regards
NT
Pathfinder Tags: PH level of treatment water
Re: PH level of Treatment water
10/26/2015 7:20 AM
Local environmental protection has the jurisdiction on this. But you may go to US EPA site, search for water quality or policies.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Hobbies - CNC - New Member
Re: PH Level Of Treatment Water
10/26/2015 9:05 AM
You need to run it through a waste water treatment facility first!
Good Answers: 122
10/26/2015 12:53 PM
Pure water has a PH of 7.
However most water in it's natural environment is slightly higher than 7 and in some cases is much higher than 7 with the nominal range being 6.8-7.3.
Even though water has a PH of 7 it does not mean that the water is safe to release for possible contact and/or use as the water could be contaminated by chemicals and/or minerals.
The allowable PH range for release of water back into a waterway, drainage, or earth is strictly controlled here in the USA by the Environmental Protection Agency (EPA) and the local city, county, and state water quality regulation standards.
The State of California Department of Water Quality standards are much more stringent than the standards of most other USA states.
The water standards also vary significantly from country to country throughout the world.
It is imperative that you review and comply with, the applicable water treatment and release standards that apply at wherever you are located.
I highly recommend and ask that you approach the release of any water back into the environment with caution and diligence as once the water gets into the waterways or into the underground system the results will be lethal.
10/26/2015 2:11 PM
Some pointers:
  • Contact the operation that already supplies sewage treatment for the facility. If it is industrial, there should already be discharge consents in place under the regime for which the facility already pays. Or look it up; someone at the facility already pays the bill.
  • Surface water run-off is not part of a sewage discharge consent as it goes directly to drainage and not sewage. However the local Environmental Protection operation will have already made observations, recommendations and requirements with which the facility must comply to avoid prosecution.
  • Local authorities will also have building regulations with which the facility will need to comply with regard to new structures. Water supply and sewage return will be encompassed by those regulations during new build and alteration projects.
Good Answers: 76
10/27/2015 10:33 AM
Not sure what country your treatment process is (will be) located, but in the US; any process/waste water treatment that discharges must be permitted through the local environmental protection agency. The resulting permit will contain the effluent criteria, along with sampling and reporting requirements.
If your process, and its discharge are of minimal impact, then you will likely fall under the general discharge permit for your area, which will also note the aforementioned sampling and reporting requirements.
Odds are though, if your process/waste water requires treatment, then a specific permit will be required.
For further information, contact your local environmental protection agency.
11/30/2015 11:08 AM
So far, all of the replies before mind have been spot-on correct. I will add that (1) if this is for Storm Water Runoff compliance within the United States, you probably will have needed to have filed paperwork with the local city codes enforcement folks, and (2) if this is water discharged into a waterway, the monitoring and constraints are more exacting.
Depending what type of facility, there can be sampling requirements, the testing of which has to be certified in a manner consistent with local codes and ordinances. If you are discharging waste water from any process (such as cooling industrial process or power generation), then you must apply for both federal and state permits with the United States, so this becomes more stringent in terms of parameters monitored above and beyond simple pH measurements. Metals, Total Suspended Solids, targeted parameters such as chloride and sulfate, chlorine, phosphate, etc. will have to be monitored. Any priority pollutants must be prevented from entering into public waterways of the governing authority where this is located (at least within the United States of America). Furthermore, within the USA, it is a felony to misrepresent any portion of the data, including the flow totals, average daily flow, etc.
If you wish to stay out of trouble, I suggest you contact environmental consulting engineers within your local governing State, and learn what the actual requirements are before you step off your horsey into shifting sand.
Register to Reply 6 comments
James Stewart (1); JavaHead (1); Legolaz (1); Original_Macgyver (1); PWSlack (1); SHOCKHISCAN (1)
