Previous in Forum: HID lighting calculations.   Next in Forum: Resistance Starters
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
RF Randomization of Lighting
07/24/2007 5:23 PM
I am looking for a way to implement RF randomization(reception of RF)into lighting(ie. flashing lights)....with each RF signal rcvd the light flashes. Also, limiting the freq. band...
Justin
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
Re: RF Randomization of Lighting
07/26/2007 2:15 AM
Give me the exact details, and I can get you whatever you need..
I would use LED as the light source, as it doesn't care how often you blink it..
Donald
Check out our home page for specs on "Soft Neon"
08/14/2007 1:22 AM
Pretty simple by sounds of it, questions a bit ambiguous. do you have an rf source already or do you need one, dose the signal need to be un modulated or is it modulated at all or is it that the lights need to pulse in time with the modulation. i suppose really i would have an antenna specific to your application, Dipole most likely, then to limit the frequency i would use a hi Q active filter ie, an LC network coupled with a cheap OP amp, then another Rf amp maybe an MMIC to boost up the RF feed that into maybe another filter that is then fed into a comparator, that outputs 5V and is then fed into a PIC which then deals with the flashing of the lights.
If the system only need to operate short distnce and you don't already have a source then that is a whole lot simpler just use a cheap $10AU 433MHz RX/TX module interface both ends a PIC. basically 2 IC's on the RX and 2 on the TX. something like this,
http://www.jaycar.com.au/productView.asp?ID=ZW3102&CATID=&keywords=433&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
http://www.jaycar.com.au/productView.asp?ID=ZW3100&CATID=&keywords=433&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID=
interfaced with say a 16F870 http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010232
AS i say a bit better explanation of the aplication and current setup and i can possible be a bit more helpful.
08/22/2007 11:01 AM
thank for the reply. Already have RF source(s). The light does need to pulse in time with the modulation. System needs to operate long distance. I just need random flash....is there a simpler approach to this?
Justin
Register to Reply 3 comments
Anonymous Poster (1); Campbell Lighting (1); justinjhosley (1)
