A bolted Joint Join 2-more components together.Bolt is preloaded by Tightening to a specified torque,it produces compressive bearing pressures below Bolt Head.
Request to provide any details if available for this allowable Compressive yield strength/Bearing pressure for the components getting clamped.
If this is not sufficient,parts getting clamped would yield, resulting in preload losses.
Request to pls provide any emperical relation if atall exists between Allowable Bearing Pressure & UTS or Tensile Yield Strength for:(AISC or ASME)
St44.2
16MnCr5
Al 6061T6
Brass
Delrin
