Previous in Forum: What a fine piece of 60+ year old engineering!   Next in Forum: Ceiling-mounted Pot Rack for Low-ceilinged Kitchen
22 comments
What is this? Where do you find it?
11/18/2015 5:56 PM
Re: what is this? where do you find it?
11/18/2015 6:01 PM
Spider gear in a differential?
11/18/2015 9:36 PM
correct!for those unfamiliar with spiders. each axle has splines on the shaft. two of the spiders will have corresponding grooves cut into them.........the spiders slide onto the axle ends. spiders come as a set of four.
11/18/2015 9:46 PM
I've had personal relationships with some of those.
11/18/2015 6:38 PM
Looks like Snidely Backlash to me....
11/18/2015 7:43 PM
Looks like a damaged gear in rear end...
11/18/2015 8:44 PM
Oh, dear, a broken Tesla?
11/18/2015 9:08 PM
I am going to hedge my bets and say a Cavalier rear end instead. Possibly a red Cavalier.
11/18/2015 9:17 PM
But, Cavalier "rear ends" are in the front.
11/19/2015 11:48 PM
A 2000 Model that won't start?
11/18/2015 9:25 PM
no goofball
Re: What is this? Where do you find it?
11/19/2015 1:00 AM
Dear Mr.Fredski,
In my opinion it is the Differential Drive for automobile vehicle and the pinion and gear is of bevel gear type.
One tooth is broken in the bevel pinion.
DHAYANANDHAN.S
11/19/2015 1:01 AM
Dear Mr.Fredski,
DHAYANANDHAN.S
11/19/2015 11:22 AM
Been there, done that! Always in the search for more power...without increasing capabilities of drive lines!
11/19/2015 10:44 PM
Rock drill.
11/19/2015 10:55 PM
What kind of forces were put on these gears to do this much damage?
Spiders gears don't do anything when you're going straight down the highway.
It would take a boat load of torque to strip these gears out just by popping the clutch on launch.
I've broken transmission gears speed shifting, but never a rear end on take off.
11/20/2015 8:13 AM
Something else breaks and falls into the works? C-clip maybe, or an improperly installed unit.
11/20/2015 9:34 AM
I would say around 350 to 500 hp and a hard clutch with a 5,000rpm hammer drop. LOL
11/20/2015 1:07 PM
sound's like music to my ears and more like 7000 to keep wheel speed up
11/20/2015 2:01 PM
I'm going to change the gearing in my Ranger. I was watching vids on 8.8 in. gear sets. I came across the pic then......not gears of mine.
11/20/2015 1:11 PM
Why do you keep asking when you already know the answer?
11/20/2015 1:19 PM
Wy not. It's fun for the rest of us.
11/20/2015 1:49 PM
Why not indeed. Unless it's a homework problem or came from a troll who changed his name. In this case a better question might have been "What did I do wrong here?"
Register to Reply 22 comments
Casper71 (1); dhayanandhan (2); Fredski (4); jack of all trades (1); lyn (5); rashavarek (1); rcapper (1); SolarEagle (1); StandardsGuy (2); Tom_Consulting (2); Tornado (2)
