Previous in Forum: Can Engineering Help Us Deal with Immigration Nightmares?   Next in Forum: Gyroscopic Precession
12 comments
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
Pressure Strip
11/19/2015 5:45 PM
We have not worked with pressure strips before.
A customer is wanting to use them to measure the contact force of an air bladder onto a surface as it pressurizes and deflects the constrained material.
Any advise on pressure strips (vendor, accuracy, use, problems, advantages, etc.) would be greatly appreciated.
Thanks.
Pathfinder Tags: pressure sensor
Re: Pressure Strip
11/19/2015 7:01 PM
transducers
Re: Pressure Strip
11/19/2015 7:25 PM
Re: Pressure Strip
11/19/2015 10:33 PM
Using a pressure strip to measure bladder pressure seems nonsensical to me.
Depends on the accuracy/resolution/error you want/can live with.
Are you gluing/laminating/bonding something with an irregular shape?
Or cracking walnuts? Sometimes I make myself laugh.
Re: Pressure Strip
11/20/2015 12:25 AM
Well, there's a lot you, or any of us, doesn't know.
Re: Pressure Strip
11/20/2015 12:23 AM
I have used these before in my life in coating & laminating.
This company has been around for awhile and were very helpful:
http://www.sensorprod.com/campaign/pressure-sensitive-paper/index.php?mcode=GC-Pressure%20-%20Pressure%20Paper%20-%203&gclid=CNWnpKCgnskCFU6SfgodiI4I-w
They even have free samples!
Re: Pressure Strip
11/20/2015 5:09 AM
If it's a bladder then surely the pressure inside will accurately reflect the pressure on the surface.
Re: Pressure Strip
11/20/2015 9:45 AM
Just use a regular pressure gauge on the connection between the incoming line and the bladder. Job done!
Re: Pressure Strip
11/20/2015 5:28 PM
Where does the 14.7 PSI atmospheric component figure into the xx PSIG reading on the gauge?
I'm trying to work this out with Common Core math logic and I can't make it figure.
Who do I call?????
Re: Pressure Strip
11/21/2015 4:41 PM
It doesn't matter.
Re: Pressure Strip
11/21/2015 8:31 PM
It may matter, depending what OP is really trying to accomplish, that he hasn't told us yet.
Good Answers: 153
Re: Pressure Strip
11/21/2015 9:53 AM
I have used pressure strips as a switch trigger but never for an analogue reading. A large force over a small area would give the same output as a small force over a large area. As the bladder inflates the area in contact with the strip changes non-linearly so there is no way you can assess the force. Also calibration would be very difficult and any tiny change in air pressure in the sealed sensing circuit e.g caused by a small temperature change, would render all readings invalid.
Good Answers: 16
Re: Pressure Strip
11/21/2015 10:34 AM
If the sensors were individually quite small in a matrix and the applied load was a spreadable bladder with known characteristics, then if the applied load was to cover an increasing number of the quite small sensors, then counting the number of quite small sensors that have a 'indicative load', could be used via a look up table to indicate the load value.
DY
Register to Reply 12 comments
Don from Oz (1); Fredski (1); jhhassociates (1); lyn (3); Mikerho (2); PWSlack (2); Randall (1); Rixter (1)
