Previous in Forum: Ring Main Network   Next in Forum: Life Assessment for Power Cable
11 comments
Separation Between 25 kV Power and Insulated Neutral Cable
02/04/2016 11:43 PM
Could anyone could suggest me what the separation would be from 25kv power and insulated neutral cable when routing same above ground cable tray from transformer to switchgear building. I found in CSA that power cables shall be 2D from centre to centre and there shall be separation between power cable to communication cable but whats about power cable to insulated neutral cable?
Pathfinder Tags: TXNW26DC
Good Answers: 445
Re: Separation between 25 kV power and insulated neutral cable
02/05/2016 12:35 AM
Exactly what is the specification for the power cable, especially its construction. I do hope that you're putting these cables in their own tray, totally segregated from any other cables.
02/05/2016 12:52 AM
power cables are 25 kv XPLE and I make separation between cable 2times dia of cables centre to centre. I am planing to put 2-4/0 insulated neutral cables in same tray along with power cables which are coming from same transformer 25 kv secondary. I would be separation between power and neutral cable as per csa or NEC
02/05/2016 6:54 PM
As long as your Cat-6 cables are rated for 25 kV what's the problem?
02/05/2016 12:56 AM
power cables are 25 kv XPLE coming from 3 phase of one transformer and I make separation between cable 2times dia of cables centre to centre. I am planing to put 2-4/0 insulated neutral cables in same tray along with power cables which are coming from same transformer 25 kv secondary. I would be separation between power and neutral cable as per csa or NEC
02/05/2016 1:14 AM
If you stick with 2D, that will almost surely be conservative on account of the lesser voltage difference. (Assuming equivalent insulation.)
02/08/2016 8:26 AM
You need to remember the purpose for the separation. Cables are primarily separated for either voltage reasons or thermal reasons. The voltage reason doesn't apply in this case and since the neutral isn' t a current carrying conductor in a balanced 3-phase system with low harmonic content, the thermal reason doesn't apply either. So, separate the cables per the code requirements (which are based on thermal requirements) and put the neutral cable anywhere convenient in the same tray.
Re: Separation Between 25 kV Power and Insulated Neutral Cable
02/05/2016 4:29 AM
Is this non-metallic tray, Mildred, or are the cables required to be 2D from any earthed part too?
Good moaning!
Good Answers: 181
02/05/2016 6:48 AM
Good question, just to add the cleats are often aluminium although plastic versions are available. I've never used the plastic version so don't know much about them.
I've always run MV in aluminium trefoil cleats so find the 2D separation of conductors strange. Whatever cleat is used it must be able to withstand the magnetic repulsion during fault conditions.
Ft = (0.17 x Ip²)/S
Where
Ft = Maximum Force per unit length of cable (N)
Ip= Peak short circuit current (KA)
S = Centre to centre distance between neighboring conductors
http://www.youtube.com/watch?feature=player_detailpage&v=HmnrJa7Zk0A#t=84s
02/05/2016 10:35 AM
I'm startled that your Client's specification doesn't tell you that, Mildred. What a bummer of a contract!
Good moaning!
Good Answers: 42
02/06/2016 12:29 AM
NEC 2014
392.20 Cable and Conductor Installation. (B) Cables Rated Over 600 Volts.
Cables rated over 600 volts and those rated 600 volts or less installed in the same cable tray shall comply with either of the following:
  1. The cables rated over 600 volts are Type MC.
  2. The cables rated over 600 volts are separated from the cables rated 600 volts or less by a solid fixed barrier of a material compatible with the cable tray.
Julius
02/06/2016 7:32 AM
And what has your Site Manager and Project Manager to say about this spacing. Perhaps asking the client or the consultant maybe a better advantage than arbitrarily asking people on this site.
I have no doubt that you have no idea about installing the cables from the Tfx on cable trays whether flat formation, trefoil, spaced, touching and where you should install the other cables for control; Bucholtz, alarms, tap changer etc.
Approved design drawings provide all this detail, you really should look at them and clarify any anomalies with the designer and consultant. (If a new build, and on existing build, still check with the designer and discover what standards he is using and referring to for your local build/repair).
God help, your cable bend radius if you don't know the spacings.
Register to Reply 11 comments
7anoter4 (1); Brave Sir Robin (1); Crabtree (2); IQ (1); mgbayer7 (1); Nitish (2); RAMConsult (1); TonyS (1); Tornado (1)
