Previous in Forum: Lunar Pics   Next in Forum: Virgin to Fly Again
15 comments
Air Speed and Distance
02/16/2016 11:40 PM
would it be more aerodynamic to make the fuselage of an airplane flat on the bottom and top to be more similar to the wings shape both top and bottom and to merg together without the sharp angle at the wing to the fuselage? It might be better to draw a picture but just look at the stelth fighter jet. Way not on all the airplanes? so what's the big secred if it'll save time and money?
Re: air speed and distance
02/16/2016 11:57 PM
Must be a full moon.
There's been two whackos already tonight.
02/17/2016 12:05 AM
Planes ... Wings need lift.. The stealth bomber is pushed around in a controlled manner and takes advantage of it's power to weight ratio. A wing shaped fuselage has been designed, but they have been difficult to push around in a controlled manner. Today's technology might allow for it, but you loose the window seating that people love. Maybe for freight.
02/17/2016 1:56 AM
Wow! No one has ever thought of that before. No wait, they did - for a split second - and dismissed it as not viable because it violated the most basic engineering principles.
You also need to work on your literacy.
02/17/2016 8:40 AM
You're wrong and there is no need to attack his literacy. English may not be his first language.
02/17/2016 9:06 AM
Attack? If English is indeed not the APs primary language, then he/she does need to work on it.
02/17/2016 9:43 AM
The rules are clear ass.. can be
CR4 is an English-speaking community. As such, all content must be posted in the English language so that it is accessible to this audience and can be reviewed properly. At the same time, it is important to note that for many users of this site, English is a second language. Therefore, there is no reason to report, highlight, or denigrate grammatical errors, typos, etc. It is also against this site's policy to denigrate a user because of his or her location, race, gender, or creed.
02/17/2016 5:58 PM
Since you feel so strongly about it, you should report me. There's a "report" button...
Re: Air Speed and Distance
02/17/2016 7:57 AM
The concept you're struggling with is called a 'lifting body'. The concept has been around since the 1950s and some vehicles have been built over the years from as early as 1962.
The US Space Shuttle made use of some of the aerodynamics learned from studies of lifting bodies.
Read more about the concept here: Lifting_body
02/17/2016 9:20 AM
Great idea, except if the top is flat, there's no way for the pilot to see where he's going.
He'd be looking straight up and not forward.
02/17/2016 9:37 AM
The top "more similar to the wing shape" That would be a bump. not flat
02/17/2016 10:17 AM
Symmetrical wings have been around forever on aerobatic planes and they fly quite nicely, so, nothing new here.
Look at a Pitts Special sometime.
Still, no place for the pilot to see out the front...................hey wait, they can lie down flat and use a periscope to look ahead.
02/17/2016 10:35 AM
True.. I think this is what the OP had in mind.
No need to lay down
Not exactly flat on the bottom either.
02/17/2016 11:27 AM
This is what i'm talking about. Thanks for your pics. My point is rather simple if you compare the wing on a bird. The wing has to go up and down to get thrust, and so it is hinged to the body thereby to do so. The lift of a plane being at the wings only and adding the weight in the center of the plane creates all the more tension on the wing. way not have that lift concept included with the fuselage as well.
02/18/2016 9:03 AM
aerodynamic, flat on the bottom as well as the top.......happy now?
02/18/2016 9:37 AM
Reply to Forum Thread 15 comments
Fredski (1); JE in Chicago (6); lyn (3); michel.t (1); Mikerho (3); Usbport (1)
