Previous in Forum: Reed valve design   Next in Forum: Air conditioner sizing
Boiler Firebars Material
07/31/2007 5:26 AM
A boiler has the following specs for the fire grates:
FC300 CAST IRON 0.5%, Cr 1%, Cu and 0.5% Mo
A replacement with these specs is proposed:
FC250 CAST IRON WITH 1% Cr
What is/are the consequences in selecting the one with 1% Cr without the other alloying materials?
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
Re: Boiler Firebars Material
07/31/2007 8:08 AM
Try www.key-to-steel.com it's a good site.
Reset, Reset
08/18/2007 11:01 PM
Cu and Mo prices are going through the roof.
And neither give great extra benefits to Anti-Scaling nor Co-efficient of Heat Conductivity--**.
**σ=C/12+Si/28+Mn/55+Cr/52+Ni/59+W/184+Nb/93+Mo/96+---------
σ being aggregate addition--gm-atom/100g
you are fine even without the Cr. But you could do with more Si ,Mn-if readily available
Register to Reply 2 comments
