Previous in Forum: Fluid Mechanics Questions   Next in Forum: Lexan (electric meter covers) Pressure Vessel Limit
16 comments
Engineering Fields - Chemical Engineering - New Member
Necessity of Dip Tube in Storage Tanks
03/11/2016 10:50 AM
Dip tube is usually employed in domestic gas-water heaters like:
I am skeptical whether i should also recommend them in large M.S storage tanks ..especially for Caustic (50wt%) tanks because caustic cause lot of foaming which may cause erosion-corrosion
Chemical Engineers are like high Temperatures & high Pressures
Re: Necessity of Dip Tube in Storage Tanks
03/11/2016 11:41 AM
First, that isn't an image of a gas water heater.
Second... what?
03/11/2016 12:46 PM
kinda like heat elements....mo flame on the inside
03/11/2016 11:41 AM
That sounds like a good idea. One thing to watch out for, though, is any sort of pressure reversal that might siphon the tank dry via the dip tube.
03/11/2016 12:29 PM
Get out much?
If the cold water inlet is close to the hot water outlet, what problems might that cause with hot water delivery?
See Tornado's response.
Some type of splash/foam control is a good idea.
That would be the job of whomever is designing the tank for you.
You DO have someone knowledgeable designing the tank, don't you?
Good Answers: 266
03/11/2016 12:31 PM
As in the hot water heater the dip tube serves a purpose. To drop the cold intake water to the bottom keeping it from mixing with the hot water at the top. I like my showers hot not tepid.
So what purpose would your dip tube serve?
03/11/2016 12:50 PM
in reading some of the replies..........are you simply "storing" fluid or using these as heated tanks???
03/11/2016 1:12 PM
Large steel storage tanks are usually built for a specific purpose and as such are built to specific standards....
http://superiortank.com/types-of-tanks/standards/
Good Answers: 92
03/11/2016 1:22 PM
As mentioned in previous posts, the dip tube in a hot water heater has as specific purpose- to ensure correct turnover of water, and to minimize the buildup off sediment.
A storage tank is different. I have often put dip tubes into blending tanks to minimize splashing and foam generation. If that is your goal, the best option is usually a bottom tank fill, secondly a dip tube, third a partial dip tube flared to dispense a stream onto the vessel wall, and finally an open drop from the top being least preferable. Why do you think a dip tube would increase foaming??
03/11/2016 1:30 PM
i should have well versed my question ..but English isn't my mother language :)
I meant that inclusion of dip tube could curb the foaming Caustic produces when is allowed to free fall in a storage tanks ..especially when tank is nearly empty.
Good Answers: 92
03/11/2016 1:48 PM
Absolutely!
Note that it requires consideration of the fill procedures as well. If the dip tube terminates slightly above the expected "empty" level, most of the air in the piping will be blown out (providing the fill rate and piping sizes have been properly correlated) before the dip tube can start "bubbling", so that there is only a bit of splashing at the beginning of the fill. My preference is usually for a 45 degree outlet on the end of the tube as well.
Of course, if the lines are blown out afterwards the dip tube then increases the foaming!
03/15/2016 4:59 AM
The reason for not filling the tank through a nozzle at the bottom needs to be revealed.
Has this plant been the subject of a HazOp Study yet?
03/15/2016 10:20 AM
Nozzles at the bottom (especially for something like caustic soda) could become plugged by carbon dioxide absorption, leading to insoluble (in the caustic soda) sodium carbonate. This is bad for business.
Good Answers: 38
03/11/2016 6:57 PM
I am a registered mechanical engineer and have been involved with the design and specification of process chemical tanks for many years, for many different chemical clients.
These are some things I have learned about inlet dip tubes for bulk storage tanks:
- There is no downside. If a tank is equipped with a dip tube it increases the cost by only a few percent. If properly constructed, the dip tube can be made to be replaced.
- They are often installed in a tank even if the liquid is not liable to foaming and may be used for another purpose later.
- For some service, they can protect the shell of the tank from localized erosion/corrosion. Highly recommended for concentrated sulfuric acid duty, as well as other acids.
- They can be made siphon proof by addition of a siphon breaker hole on the tube near the roof of the tank.
- Many chemical companies have developed standard dip-tube designs and include these when a new tank is purchased.
- When dip-tubes are properly grounded, they can prevent electric charge build-up during filling for selected polar liquids such as HCl
There are other discussions on the internet regarding pros and cons of these devices
03/13/2016 1:21 PM
Sir can you please elaborate this
03/14/2016 10:03 AM
It is a small hole near the top of the fill line to break siphon if there was a chance of flow reversal, so that the line start sucking in air, and siphon effect is killed.
If you are having a bulk tank that requires heating in a cold climate to prevent crystallization of the material (i.e. high concentrations of caustic soda), then you would also need to provide for internal circulation of the tank perhaps, or this might be done by normal thermal circulation if the tank is not too large.
07/17/2023 5:07 AM
<...large M.S storage tanks ..especially for Caustic (50wt%) tanks because caustic cause lot of foaming which may cause erosion-corrosion...>
According to this: Chemical Compatibility Database from Cole-Parmer United Kingdom (coleparmer.co.uk), these two materials are incompatible with each other, and the effect of <...foaming...> is therefore irrelevant.
Register to Reply 16 comments
Doorman (1); Fredski (2); James Stewart (2); JNB (2); lyn (1); MJCronin (1); nightcrawler (2); ozzb (1); PWSlack (2); SolarEagle (1); Tornado (1)
