Previous in Forum: Picking the Proper Bulb for My DIY Spectrometer   Next in Forum: Turbomach TTS4 Control System
10 comments
Level Sensor for Tank, High Viscous Product
03/14/2016 8:11 AM
We storage a highly viscous product in a tank (11 m height; 8 m diameter); It's a sticky product, like honey, but it could be storaged uptto 20000 cP, 10°C. Highly Viscous. The densitiy if variable (We could storage 3-4 products of different density, viscosity)
I have read about several level measurement technologies, but none of them convince me completely about its success about our application:
Mechanical Floats & Displacers: the product can buildup on the float or displacer and we could need several recalibrations for the different densities.
Differential Pressure: Recalibration and I don't know if it is suitable for 20,000 cP. I think cleaning could be a problem
Ultrasonic: I think this could work, but we have two of them on another tanks of similar characteristics and they don't work properly. I think it is because we have air handling units that inject air constantly. this can obstruct the sound waves of the ultrasonic sensor.
Pulse Radar: It is affected by the dielectric constant. Our product is refined (0 conductivity). I think it will not work
Guide Wave Radar: It is not affected by density, dielectrics or temperture, but i don't know if there are probes up to 10 m, or they will have build-up problems.
If someone knows what it is the better technologie of level measurement for this, or have seen working some of them for a similar application, please let me know.
Thanks.
Re: Level Sensor for Tank, High Viscous Product
03/14/2016 8:41 AM
Google optical level sensors
03/14/2016 8:57 AM
  • Put the tank on weigh-cells.
  • Non-contact radar.
Good Answers: 176
03/14/2016 9:03 AM
I have never used it, but optical infrared might be worth looking at.
Both guided wave and pulse radar react to the change in dielectric as the basis of their detection technology.
The obvious problem with guided wave is build-up on the probe.Your material has some dielectric value, all refined products do.
Non-contact radars can produce a reading with quite low dielectric materials and generally don't care about the atmosphere - whether it is vapor, mixed air and vapor or mostly air like ultrasonics does.
For the non-contact technologies, keep the unit away from the side wall to prevent reflection problems.
03/14/2016 9:52 AM
I forgot to say. The instrument is required for continuous level measurement. Is it used optical technology for continuous measurment or only for point measurement (level switches)?
Good Answers: 176
03/14/2016 12:55 PM
The technology is correctly called laser, not infrared. Yes, it is continuous level measurement, not point level. Opacity of the liquid affects the measurement.
ABB bought K-Tek. Might be worth a call to ABB.
http://new.abb.com/products/measurement-products/level/laser-level-transmitters
Anonymous Poster #2
03/14/2016 9:34 AM
03/14/2016 9:38 AM
03/17/2016 10:08 AM
I think he is wanting a level (reading from bottom to top allowable in a continuous range, and readings constantly updated) not a level switch type sensor.
The item you pointed out is surpassing (as usual) for a liquid level switch application, not so much for actual tank level in feet.
03/14/2016 10:26 PM
The crude oil guys have a pressure system that's not dependent on density I think. Don't remember more.
03/17/2016 10:02 AM
I personally would choose radar or wave-guided radar, simply because, it relies on a reflected radio signal, and I am pretty sure your whatever viscous chemical will not be "stealth" material, thus radio will reflect. I don't even think wave-guide radar is needed, but do talk to the product specialists on this before decision time. They might even advise to have redundant sensors installed so switch-over is instantaneous if need be when PM is done on any sensor that has "glazed" over.
By the way, I suspect differential pressure will work, however slow in response in this instance. Fouling of the sensor diaphragm can be avoided, if the interstitial space between tank and sensor flange is some how filled (use a density trap) with a less viscous (non-contaminating, non-reactive) fluid. It is not insurmountable, just probably more trouble than it is worth to you.
Register to Reply 10 comments
Anonymous Poster (2); badbob (1); ChemistUSX (1); Fredski (1); Iris (2); James Stewart (2); PWSlack (1)
