Previous in Forum: Sand Trap Louver   Next in Forum: Steam Table
20 comments
PTFE on Gas Service Not Approved
03/29/2016 5:56 AM
All,
Is it suitable to use PTFE sealant on hydrocarbon service. I have heard and read that is an unapproved sealing method.
Re: PTFE on Gas Service not approved
03/29/2016 6:55 AM
If it has been deemed unapproved, then clearly it is not suitable according to those doing the deeming. So why the question?
Good Answers: 120
03/29/2016 7:14 AM
Yes, they make a tape for that use, it is thicker
Per Ardua Ad Astra
03/29/2016 7:29 AM
<...they...> Who?
Good Answers: 120
03/29/2016 7:32 AM
TAPE COLORDESCRIPTIONEXAMPLE/TH>
Whitesingle or double density, should only be used on NPT threads up to 3/8 inch in diameter
LASCO White 1/2-Inch Double Density PTFE Thread Seal Tape
Yellowdouble density, often labeled as "gas tape"
Oatey Yellow 1/2-Inch Gas PTFE Thread Seal Tape
Pinktriple density, required on all joints 1/2″ or larger
LASCO Pink 1/2-Inch High Density PTFE Thread Seal Tape
GreenOil Free PTFE tape, required for use on all lines carrying oxygen (i.e. - medical oxygen or welding oxygen lines)
Gasoila, 1/2-Inch Green PTFE High Density Thread Tape, 3.7 mil Thick
Per Ardua Ad Astra
03/29/2016 7:40 AM
Very useful. Thanks. :-)
03/29/2016 7:49 AM
<...read that is an unapproved sealing method...> Please advise the nature of the source document, given the content of #4 above, showing gas service, which is one of a range of <...hydrocarbon...> materials?
Good Answers: 120
03/29/2016 8:12 AM
Per Ardua Ad Astra
03/29/2016 8:28 AM
Then it would appear that the original poster is mistaken. Thanks. :-)
Good Answers: 120
03/29/2016 8:38 AM
hydrocarbon based tape is penetrated by CH4 molecules via molecular diffusion and made more fluid and subject to gradual pressure extrusion from the joint.
Much like paint thinner on paint where methylene chloride penetrates paint films.
Per Ardua Ad Astra
03/29/2016 9:15 AM
Thanks. Useful to know. :-)
03/30/2016 9:23 AM
Isn't AP#1 USUALLY wrong?
Then AP#2 shows up to say impolite things about AP#1?
HAS AP#2 shown up yet? Or are we going to have a civil conversation for once?
Good Answers: 92
Re: PTFE on Gas Service Not Approved
03/29/2016 8:55 AM
Note prior posts from Aurizon. In addition, Read the label!
There are tape, paste and solid (putty stick) sealant products available for pipe thread sealing. Not all contain PTFE. The label (on everything but the cheap white tape at the hardware store) should indicate, for example "UL listed for use on water, steam, natural gas and gasoline service on threaded joints up to XXXXXX...". Just asking about hydrocarbon service is not specific enough.
03/31/2016 3:07 PM
Don't matter. The info we are getting is that if you return a thermostat or safety valve as defective and the factory finds teflon tape in it, the warranty is voided. Not a matter of compatibility, a valve intended to control low pressure (3.5 w.c. in.) gas cannot work with pieces of tape in it. -- JHF
Good Answers: 120
03/31/2016 3:16 PM
So they take the stand that the threads will cut tape - a more or less 2 dimensional material - into small strips and fragment that could enter the innards of the valve, which is, I agree, susceptible to obstruction and 2 to 3 inches of water pressure differential.
They should open the valve to determine the true cause, and if a tape fragment and that is cited in the warranty as cassus belli(economic - against you!!).
It has some validity as a paste will tend to cohere and harden and not make such particles, and any that occur will fall under gravity to a low point??
Per Ardua Ad Astra
Good Answers: 203
03/31/2016 4:06 PM
I was told many years ago not to use tape on instrument air lines. It could block off some of the small orifices in regulators and similar parts of the system.
A few people have also said not to use tape on any part of a compressed air system for the same reasons.
My practice is to make sure none of the tape is placed forward of the threads, over or onto the end of the pipe. If any gets cut it will not go into the pipe and will be smashed by the threads as the fitting is tightened. Otherwise I will use a Teflon paste, preferably of the better types of Teflon paste.
Good Luck, Old Salt
03/29/2016 12:27 PM
The question is too vague...I don't know any pro's that use tapes as sealant...but there are PTFE paste sealants for use with hydrocarbons....Teflon is more for lubrication, as in ease of tightening, than for sealing threads as in thread sealant...
http://bluebarrel.eu/shop/chemola-desco-valve-lubricants-and-sealants/tfe-104-hydrocarbon-service-contains-ptfe/
http://www.plantengineering.com/single-article/guidelines-for-choosing-a-pipe-thread-sealant/5103ee62235def2053cec5d46dd34156.html
03/29/2016 6:31 PM
Yeah, the stuff I use for my gas lines looks like grits (but more opaque and whiter color). It never really hardens which I guess is the point.
Good Answers: 109
03/29/2016 11:50 PM
To wrap it up: only suitable PTFE sealant is allowed for hydrocarbon service!
Yet to discuss approved or un-approved by whom???
03/30/2016 5:50 AM
Approved or unapproved? either way is there a quality control audit trail to a source of authoriy? - a standard?, an insurance company?, a trade association?, a professional institute? - we do like to get our facts right!,
06/10/2016 2:19 PM
One thing that was not talked about was the TYPE of threads being used. If they are 'straight' threads (like on water pipes) then PTFE tame or pipe dope is needed to seal the threads, if they are 'compression' threads (male end looks like it has a cone-like tip ahead of the threads) then additional sealants are NOT required, and NOT allowed.
Reply to Forum Thread 20 comments
adreasler (2); aurizon (5); Brave Sir Robin (1); Circuit Breaker (1); horace40 (1); IdeaSmith (1); JNB (1); old salt (1); PWSlack (6); SolarEagle (1)
