Previous in Forum: The Implosion Motor Based on the Clem Engine   Next in Forum: Name for Valve Sizing Software
8 comments
45*45 Elbows in Sewer
04/11/2016 3:36 AM
I have inspection chamber (60*60 cm) inside the villa yard (Between the villa building and the fence surrounding the villa). This I.C delivers wastes to another I.C (90*90 cm) out of the fence (In the walk way) which is 13 m far from the 1st I.C.
- Obligatory, I have to put a 2 45 elbows 2m Before the I.C in the walk way.
Is it permissible or not???
Re: 45*45 Elbows in sewer
04/11/2016 4:04 AM
As long as they are radiused, continue the downward angle(3/8" per ft), and are at least 12" or more apart, I don't see a problem.....
04/11/2016 4:17 AM
...and also consult your local codes and authorities for any requirements about how much distance and how many fittings are allowed between cleanout access points.
04/11/2016 4:22 AM
<..Obligatory...permissible or not?...> If something is obligatory then its permissibility is not open to question.
04/11/2016 4:36 AM
...and even more importantly, vice versa.
04/11/2016 4:53 AM
Quite.
04/11/2016 8:05 AM
Not knowing the type of joints, just putting this out there, is blocking required?
04/11/2016 8:36 AM
That would depend on your local code of practice.
If they are to provide depth change for fall across block, then probably correct. If they are in horizontal then probably not OK.
Good Answers: 70
Re: 45*45 Elbows in Sewer
04/11/2016 11:29 AM
Your handle (name) Trueengineer is deceiving. A True Engineer would already know the local codes, how to look them up, do their own research or who to contact if there is a question. You need to do your own homework, you'll learn better by doing so.
CR4® is a world-wide forum and you haven't told us where is this world wide area your are in or where the job site is located, until then, it's anybody guess
Oh yeah, welcome to CR4
Register to Reply 8 comments
dj95401 (1); Just an Engineer (1); phoenix911 (1); PWSlack (2); SolarEagle (1); Tornado (2)
