Previous in Forum: Help Please - Calculate "Over Time Rate" for LED Emergency Lighting   Next in Forum: MVAJ Relays
Generator
05/05/2016 4:23 AM
Hello everyone
My question is that why we turn off capacitor bank while switching on generator.
& i connected capacitor at load side. i dont turn off them hence that load side capacitor will draw extra current. ?
Re: GENERATOR
05/05/2016 4:40 AM
Google says: a lightly loaded system with capacitance connected can cause over-voltage & leading power factor problems.
Re: Generator
05/05/2016 6:45 AM
Surely that is explained in the organisation's Standard Operating Procedure documents?
Re: Generator
05/05/2016 8:06 AM
Once the total load on isolated generator can be subjected to changes with time a capacitor are connected for pf perfection might suddenly causes the total load to become capacitive. Sometimes the total components have an unsafe effect on the capacitors bank. So, it is highly suggested to control this values of the harmonic.
Control Panels India
Re: Generator
05/06/2016 6:28 AM
Every generator has limited capability to operate under leading power factor load which may be governed by its END ZONE HEATING limits and / or margin on stability. (load angle approaches 90 degree).
If you do not turn off the capacitor bank, the resultant power factor as seen by the generator will depend on amount of load and its power factor.
Re: Generator
05/06/2016 10:25 AM
I'm thinking that what is happening is due to the voltage regulator cross current compensation.
When a generator is paralleled onto a bus, if the generator voltage is not set equal to the bus voltage, reactive current will flow between the generator and the bus. This reactive current is sensed by the cross current compensation circuit in the voltage regulator which corrects the voltage setting.
The reactive current caused by the capacitor bank would give the same indication to the cross current compensation circuit as an incorrect voltage setting and cause an improper voltage adjustment.
http://esrdc.mit.edu/library/ESRDC_library/VR_parallel.pdf
Re: Generator
05/07/2016 2:17 AM
Dear Mr.ashitoshchougle,
If the Capacitor BANK is on Line, (while starting the Generator, there will be NO-LOAD on the Generator) the capacitor will be working as load and it will result in HIGHER TERMINAL VOLTAGE and the Power Factor will be LEADING P.F. Pl. refer a Standard Electrical Technology Book for the related VECTOR DIAGRAM.
The higher terminal voltage will cause damage to the equipement. Hence the capacitor bank should not be switched on before loading the Generator, and as when the P.F is to be improved, the capacitor bank should come on-line.
DHAYANANDHAN.S
Re: Generator
05/10/2016 7:41 AM
In some older switchboards there used to be a Hand-Off-Auto switch for power factor correction, problems could arise (did) in one case that I investigated of the switch left on hand. Was concluded this damaged the generator diodes when the stand-by generator started.
Register to Reply 7 comments
dhayanandhan (1); highvoltpower (2); lyn (1); pcchatur (1); PWSlack (1); Rixter (1)
