Previous in Forum: Changing Transformer Primary Winding   Next in Forum: Can A Utility Electric Meter Read Generator Power Supply?
LV Switchgear Selection
05/27/2016 2:43 AM
Please help me for following queries,
1)why neutral needs to on-off with phase in TN IT TT systems i.e neutral to be taken as pole
2)When can we use neutral as neutral link in sub distribution Board/Panel.
3)I have to design a distribution board/Panel for Power Sockets,Can i Take incomer as TP MCCB with neutral and all outgoing feeders to sockets as TP MCCB/MCB with neutral link
4)when can I take Incomer and Outgoing feeders as TP MCCB/MCB and neutral as neural Link.
-Thanks in Advance
Pathfinder Tags: LV SWITCHGEAR
Good Answers: 181
Re: LV SWITCHGEAR SELECTION
05/27/2016 5:04 AM
This looks like homework. If we do your homework you won't learn.
05/27/2016 5:30 AM
actually its not a homework..i took the most basic situation..I understand the selection criteria for 4P TPN n all..but always find literature missing for consideration of neutral link where i hav reviewed many design with the same.So please help me solve where neutral link is mandatory.!
05/27/2016 5:20 AM
A1) -
A2) Only when it says so on the "approved for construction" drawing.
A3) Only when it says so on the "approved for construction" drawing.
A4) Only when it says so on the "approved for construction" drawing.
05/27/2016 5:41 AM
But my concern is whn it is mandatory to provide neutral link or when it is ok to provide neutral link..
Good Answers: 181
05/27/2016 5:52 AM
All service conductors must be switched at the intake point. Exceptions apply for private networks.
Anywhere after the service switch, advisable with some supply systems
As above
As above
For all outgoing ways a removable neutral link is an advantage for testing. It won't be the first time I've seen it left out after testing.
05/27/2016 6:24 AM
Thank u sir :)
05/27/2016 2:51 PM
Well and succinctly stated, sir, salute! I even learned something today that actually made sense.
Register to Reply 7 comments
Anonymous Poster (1); James Stewart (1); PWSlack (1); Rajvi (2); TonyS (2)
