Previous in Forum: NEMA 34 Stepper Motor Dimensional Size Question   Next in Forum: Noise From Water Pipes
22 comments
Need Help Selecting a Motor Type
08/14/2016 8:24 AM
Which type of motor would be best suited for lifting thousands of tonnes (e.g 3000 tonnes). I am designing a motor that will turn a drum with ropes that will hoist a ship lift (three gorge dam).
Pathfinder Tags: heavy load motor selection
Re: Need help with selecting a motor type
08/14/2016 9:54 AM
That's it? That's all the information you're going to give us. A (one and only one) drum (of steel, titanium, hollow, solid) will spin with ropes (two or more made of sisal, nylon, woven spider silk) to lift a 3000 tonne ship somewhere near or around the massive three gorge dam.
I will gladly help students that demonstrate an effort in doing their homework. You have not demonstrated any knowledge or effort on your part to solve this problem. I cannot help anyone that doesn't understand the question, let alone an answer.
08/14/2016 1:17 PM
Hmm, lazy and vindictive is not a good combination in engineering.
08/14/2016 1:45 PM
I'm surprised Wu Wu figured that out so quickly.
I fixed those that I could.
If the truth hurts, maybe it should!
08/15/2016 2:41 AM
They learned it from management.
Damn those engineers for being such clever and observative bunch.
08/14/2016 10:40 AM
I'd go with a really, really big blue electric one.
Better yet, make that a humongous, orange electric one, with big wires.
Talk to a motor supplier. They need a good laugh too.
08/14/2016 11:14 AM
Of course it's not nearly so simple, you must first have a design for the lift that will define the needed motor sizes, because there will be several motors needed...The weight will need to be counter balanced to make it more efficient, you will need many pulleys and ropes...Here are some details on the current design being used...
http://probeinternational.org/library/wp-content/uploads/2011/01/Ship-lift-at-Three-Gorges-Dam-China-design-of-steel-structures.pdf
http://www.altramotion.com/newsroom/2016/03/ap-svendborg-bsfi-braking-systems-for-dam-ship-lift
08/14/2016 11:51 AM
Thanks for that. I see they went with really, really big blue electric motors in their final design.
That should help the student with his motor"design".
<Beaming up now>
Re: Need Help Selecting A Motor Type
08/14/2016 11:44 AM
A Saturn V rocket engine sounds about right.
08/14/2016 1:05 PM
Might a system of locks have been considered as an alternative?
08/14/2016 1:59 PM
They have a lock system as well....The lift is much faster though...Think of it as the HOV lane of river travel....
08/14/2016 1:13 PM
One possibility would be a constant-torque variable frequency drive with matched motor. A mechanical alternative would be to include a centrifugal clutch or torque converter in the drive train.
08/14/2016 2:09 PM
Well I think an alternative drive would be direct drive from a Pelton wheel that would be driven hydraulically coupled to a geared lift with a shift capability from up to down...but that probably would have to be part of the original design...after the fact you have to go with what works...
08/14/2016 4:25 PM
I seriously doubt that for a number of reasons, one being that this sort of question is handled by paid Engineering firms employing consultancy companies, the other being construction of the three gorge dam's ship lift was completed in January 2016 by Lahmeyer.
Three_Gorges_Dam
If this is a school project or general interest try performing some research into the dam itself and those like Lahmeyer who were involved in the ship lift design.
If you meant that you are working on something SIMILAR to the Three Gorges Dam lift, why are you asking us?
08/15/2016 3:32 AM
The motor power is the rate of change of potential energy divided by the system efficiency. Since there is nothing in the original post about speed, it is not possible to size the motor.
  • It is perfectly possible to use the power of falling water to provide the lift, thereby not needing a motor at all. That is how locks work on a canal. The technology is over 200 years old, i.e. predating the electric motor era.
08/15/2016 5:57 AM
The best type of motor for your purpose would be:
#1: American Made
#2: Capable of handling the torque required
#3: Capable of providing the speed required
A: a small appliance clock motor will lift the ship if gearing is sufficient,and time is not a factor.
#4:Capable of the duty cycle required
#5:Capable of surviving the environment in which it will operate
#6 Capable of using the available power to the site.
A: Remember,if the motor is too large you may overload the generators at the site,resulting in a catastrophic failure of the entire electrical grid.
Simple solutions for a simple problem,as described.
08/15/2016 6:02 AM
Here is a motor/gear combination that is EXACTLY what you need:
Lots of torque,but slow......
http://sploid.gizmodo.com/this-mind-bending-machine-completes-one-turn-every-2-3-1457516789
08/15/2016 10:54 AM
In a couple of centuries, it should have the backlash out.
08/15/2016 11:23 AM
Sooooo.. How much HP to lift a 3000 tonne ship in 2.3 trillion years? I was planning on using 2 AAA batteries. What type of Battery will last 2.3 trillion years. OOOPS! Forgot to get lift height. I'll get back with you on that in 1000 years or so. I will be on coffee break for a couple of centuries. -- JHF
08/15/2016 6:13 AM
08/15/2016 10:41 AM
Is the water over your head? It seems that this project is. -- JHF
Canada - Member - New Member
08/15/2016 10:58 AM
"Designing" a motor is best left to the electric motor manufacturers, unless of course you happen to work for one of them, and then the information should be readily available. If you are needed to "specify" and electric motor, contact the manufacturer and they can supply you with a catalogue or a link on line.
However, as suggested elsewhere in this thread, you are missing an awful lot of other details to complete the selection.
Never stop learning
Good Answers: 266
08/15/2016 1:32 PM
Why design anything. The draw works from a drilling rig.
http://www.drillingformulas.com/block-and-drilling-line-calculation/
Register to Reply 22 comments
Circuit Breaker (2); HiTekRedNek (3); jack of all trades (1); Jpfalt (1); Kevin LaPaire (1); lyn (3); ozzb (1); phoenix911 (1); PWSlack (1); redfred (2); SolarEagle (3); tcmtech (1); Tornado (2)
