Previous in Forum: Efficiency Calculation For A VFD Drive   Next in Forum: Powerflex 70 with Multiple Motors
10 comments
Motor Control And Drive
08/17/2016 3:17 AM
explain the effect of the following condition to dc motor
a)mechanical overload
b)supply voltage changers
explain the effect of the following condition to ac motor
c)single phasing
d)frequency changers
please urgent!!!!!!
Re: motor control and drive
08/17/2016 3:39 AM
No... shalln't
How about a nicely constructed question, or a context or maybe a "please"?
I'm not doing you homework!
Good Answers: 181
08/17/2016 4:08 AM
No one will do your homework on here
08/19/2016 1:41 PM
That would be 'e'
e) No one will do your homework on here
08/17/2016 5:41 AM
Writing a whole post in all-caps, boldface, or italics is considered as shouting.
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
Re: Motor Control And Drive
08/17/2016 8:16 AM
Oh pur-lease!
Why would we help someone who can't be bothered to read his own notes (attend lectures?) to become an engineer?
Chaos always wins because it's better organised.
08/17/2016 8:54 AM
Do these terms mean anything to you?
Good Answers: 804
08/17/2016 11:05 AM
Must be a management student, learning how to get other people to do their work for them rather than learning how to do it themselves...
08/17/2016 1:12 PM
For DC motor
Mech.Over load, - motor can stall, shaft may brake, and over current will be after effect, fuse may blow, or motor will trip
Supply Voltage changes - power out put by motor will fall speed also falls.
For AC motor
Mech.Over load, - motor can stall, shaft may break, and over current will be after effect, fuse may blow, or motor will trip
Frequency changes - speed will vary proportionally. If over frequency, speed will proportinally increase, power demand will vary as cube of speed - If the drive is for the pump - the pressure will vary as the square of speed. affinity law comes in to picture.
Single phasing, motor will continue to run in 2 phaase, over heating of winding will ocur.
Supply Voltage changes - power out put by motor will fall., will try to draw more current, Speed also falls,
DHAYANNADHAN.S
08/18/2016 3:11 AM
Thank you so much.. I appreciate your answer..
08/17/2016 10:07 PM
A: explain the effect of the following condition to dc motor
The answer to A is b)
B: explain the effect of the following condition to ac motor
c)single phasing
The answer to B is a and c)
Register to Reply 10 comments
danialyel (1); dhayanandhan (1); English Rose (1); JRaef (1); lyn (1); phoenix911 (1); redfred (1); TonyS (1); Tornado (1); user-deleted-1105 (1)
