Previous in Forum: What's the effect of diode change using different W but same V   Next in Forum: I Want Brief Explanation About AC Current And DC Current
How to make tranducer to change 0-60mVolt become 0-5 Vdc?
08/07/2007 6:47 AM
Dear all,
I have a DC Shunt in my rectifier system with output 100Amp & read as 0-60mVolt,can read positive & negative current.I want to make input analog for my controller (using PLC,Programmable Logic Controller) which can read analog input 0-5Vdc.How can i make a tranducer or comparator to have the output from DC shunt 0-60mV change to 0-5 Vdc which can accomodate the positive current (charge) & negative (discharge current from battery) & can be use as analog input for my PLC
Anyone can help me please? Or any product for these need?
Regards,
Imam Yulianto
Jakarta - Indonesia
Re: How to make tranducer to change 0-60mVolt become 0-5 Vdc?
08/07/2007 7:07 AM
What is needed is a galvanically-isolated amplifier. Lee Dickens used to produce these a few years ago (the "alphabet blocks") and probably still do (usual disclaimer applies: the only connection is as a satisfied Customer).
08/07/2007 7:23 AM
If you want top diy it sounds like a job for a couple of opto isolators and an op amp or two....
(Sorry my enthusiasm runs out about here... Ohh did you see Kris's link to the Mrs Zambesii, Currys brain sketch? Brilliant...It'll take your mind off work)
08/08/2007 3:44 AM
Is you PLC a fixed block type with only 0/5 volt analogue inputs is is it the rack type with plug-in I/O cards? If the latter then most PLC's have a thermocouple input card available, most thermocouple cards nowadays are isolated input type. You can then scale the PLC bit count to suit your 0/60mV input range.
I have done this application and it works OK.
If its the fixed 0/5V input type then you can get an isolator/convertor from www.amelec.ltd.uk
08/15/2007 1:40 AM
This is the best way
Anonymous Poster (1); MUKULMAHANT (1); PWSlack (1); user-deleted-1105 (1)
You might be interested in: Shunt Resistors, Data Acquisition Input Modules
