Previous in Forum: Chocolate Transferring: Lobe Pump Issues   Next in Forum: Carbide cutter
Treatment to Reduce Forging Die Wear?
08/10/2007 4:32 AM
I am looking for a forging die face treatment to reduce wear.
The forging billet is pre heated to around 1000c.
Re: Treatment to Reduce Forging Die Wear?
08/10/2007 10:20 PM
yes i think i can help on that with electric heating. can you tell me how long you need the heat and in %f?
08/10/2007 11:31 PM
if the die is 300 stainless, hastelloy or duplex try Kolsterising.
Surface harness of 68 HRc without dimensional change.
www.kolsterising.info
08/11/2007 12:56 AM
How about Glass powder spraying often?
08/13/2007 8:48 AM
If using A-2 or D-2 steels I would strongly recommend Vanadium carbide coating, 3600 vickers hardness and applied via a thermal diffusion process, see:
http://www.tdcoating.com/index.php
Regards
07/29/2008 1:13 PM
Thermal spray treatment or electrospark deposition with carbides, borides, etc that retain hardness at 1000 C is what may be required. Some superalloys also provide enhanced wear resistance at high temperatures. Please contact technovationsintl@gmail.com for further help. Ram K. Iyengar, Ph.D
Anonymous Poster (2); BillM (1); MUKULMAHANT (1); southern_stress (1)
