Previous in Forum: R448AVR in Place of R449AVR?   Next in Forum: Stepper Motor Failing--Electrical Interference?
68 comments
Engineering Fields - Mechanical Engineering - I am here to help!!
Power Supply and Timer
12/18/2016 10:25 PM
Hi,
I am a mechanical engineer and for some project I need some information. So, I thought this is the best place to ask. I googled but didnt get proper results.
1. How can I reduce or vary electrical power supplied to my unit? are there any cheap or ready-made devices or can I make something at home?
2. Are there any power on-off devices which can switch the power on and off at an interval selected by me? Again, are there any cheap or ready-made devices or can I make something at home?
Thanks in advance
Re: Power supply and timer
12/18/2016 10:31 PM
What is your "unit"?
Pool timers should work.
Not much to go on.
Amazon.com: Pool Timers: Patio, Lawn & Garden
12/18/2016 10:58 PM
Its a water heater or steamer
12/18/2016 11:07 PM
I have such a timer on my water heater.
They work very well.
You could reduce the temperature at which your heater maintains the water.
12/18/2016 11:10 PM
Do you know any cheap ones like China made !!!
12/18/2016 11:09 PM
This type device would normally be controlled with a thermostat, not varying the voltage...
12/18/2016 11:11 PM
What does the 'power supply' part of the post's title refer to? Are the mains the 'power supply' to which you refer?
Is this a residential water heater? An industrial water heater? One to warm your tea? A boiler to make your steam? I'm not sure what you mean by 'steamer.'
Throw us a bone, mate. What exactly are you wanting to control?
12/18/2016 11:16 PM
You are right!!
I am talking of controlling the mains voltage going to my device.
Its a study project, they want something to keep water warm at constant temp and also produce steam at constant temp.
12/18/2016 11:27 PM
How much water? At what temperature? How much steam? Temperature? Pressure? Flow rate? Are these two separate devices? I'm asking because merely 'warm' water does not produce steam. Vapour yes, but not steam like for a steam turbine or something. How much power are you looking to control? Watts? Kilowatts? Megawatts?
1.21 gigawatts!?!
12/18/2016 11:35 PM
I really apologize for not providing all the information. But, I really dont have it.
All I can say that they want to combine a water heater and steamer that will give controlled output i.e. not too hot!! so hot water like for tea and hot steam like for facial spa.
Water reservoir may not exceed 1 lire capacity and heating coil is not yet selected. They are just looking for alternatives.
12/18/2016 11:44 PM
To make steam you've got to boil the water. How can boiling water be made 'not too hot'? Sounds to me like you need two heaters - one to maintain water temperature in one reservoir and one to boil water separately to make steam.
12/19/2016 12:07 AM
But if I can control power input I can provide just as much power to heat water or to produce steam.
So, it will be a container with a single heating coil which will be used to heat water from just a warm temperature to boiling hot and again maintain that temperature constant
12/19/2016 12:19 AM
That's more like it. Now, how do you plan to cool the water back down to the setpoint temp? Just let it cool naturally?
Sounds like what you need is a simple thermostatic temperature controller that switches the heater on and off to maintain temperature, and an override switch that lets you turn the heater on full time to make steam. Does the steam have to be on a timer? In other words, is the whole thing automatic? If so, as the same heating element is used in both cases the output of the thermostatic controller can be wired to the heater in parallel with the timer.
12/19/2016 3:04 AM
I was actually thinking about some electrical device connected between the mains and the heater. This electrical device will have two knobs. One knob will act as a timer to keep the device on as dictated by the timer scale. Second knob will control the mains power that is supplied to the heater, in other words the heat produced by the heating coil. This way I can produce hot water, just warm enough to drink or make the water boil enough to produce facial spa that wont burn my skin.
Again, for the second knob, instead of controlling the mains power, I was thinking of switching the supply on and off at regular interval to control the heating of coil. What do you suggest is the better option?
Keeping aside the power requirement and all, I am just looking for some cheap or home made electrical devices that can do the job.
"in both cases the output of the thermostatic controller can be wired to the heater in parallel with the timer"
As you rightly suggested, are there any available devices you know of or can I make it at home? Do you have any expert opinion on this matter.
12/19/2016 11:24 AM
If you're heating just a litre of water and your heating element at full power draws at most a few hundred watts, use an ordinary lamp dimmer to regulate the water temperature. Of course you'll need a thermometer to know what that temperature is, and at a given power input the water temp will vary depending on ambient temperature. That's the beauty of using a thermostatic control, it takes care of your temperature measurement and regulation in one go.
12/20/2016 10:40 AM
Very good - I see you are new to this site, and already you've garnered a couple of GA's, on a post with too little information provided for most Gurus to even try to answer. We need more like you.
12/20/2016 10:43 AM
That's because he one of us Texans that pays no attention to the "Road Out Ahead" signs, and just plows right on through to a probably useful answer if not the best one.
Cheers! Merry Christmas!
12/20/2016 10:48 AM
I've been in Texas and in most of it, a "Road Out Ahead" only means you drive around the bridge that is down and through that little gully. Never been to the far west where I guess you actually have ravines.
12/20/2016 11:26 AM
Yes, those ravines are real spoilers. Hold my beer and watch this, the most famous last words in Texas!
12/20/2016 11:58 AM
With the heavy rains we've had here the last few years, you don't have to wait long or look far for a washed-out road. Last flood we had, two bridges were under water within a half-mile of here, the nearest one at the end of my lane. The water was seven feet over that bridge and about ten feet over the other one. The current was so strong it stripped the asphalt off the far bridge which, amazingly, did not collapse. If this happens again next year I'm getting one of these:
President Johnson (who was from Texas) had one and liked to have some fun with it:
The President, with Vicky McCammon in the seat alongside him and me in the back,was now driving around in a small blue car with the top down. We reached a steep incline at the edge of the lake and the car started rolling rapidly toward the water. The President shouted, "The brakes don’t work! The brakes won’t hold! We’re going in! We’re going under!" The car splashed into the water. I started to get out. Just then the car leveled and I realized we were in a Amphicar. The President laughed. As we putted along the lake then (and throughout the evening), he teased me. "Vicky, did you see what Joe did? He didn’t give a damn about his President. He just wanted to save his own skin and get out of the car." Then he’d roar.
--Joseph A. Califano, Jr
12/20/2016 1:19 PM
The year I spent down there in the "nation" of Texas, you were having an extended drought. No fear of wash outs or bridges under water that year. Did get a lot of "it usually is wet here" comments when touring with a native Texan around Beaumont and Houston.
Saw those things on Lake Erie when I was a teenager. Pretty neat transportation devices. Don't know why they didn't catch on.
LBJ. Unfortunately I was just that right age then, where I and my friends didn't really appreciate his efforts. Now I know he was a very good President.
12/20/2016 1:35 PM
Yep. The weather here is either feast or famine. Not much in the way of middle ground.
I saw an Amphicar only once, in Washington state I think. We were on holiday, on our way to British Columbia, and were passing a small lake. There it was, driving down the boat ramp into the water. Dad pulled off and we watched it for awhile. He'd never seen one either and thought perhaps it was a one-off; something the guy had invented. We all thought it was really cool.
Turns out these were produced in small quantities by a German company for a few years in the 60s. I don't know why they didn't catch on. It wasn't a very good 'boat' - more of a novelty, really - and possibly it wasn't a very good car, either.
12/20/2016 1:49 PM
My Uncle William, while a corporal in the U.S. Army in Europe during WWII, came up with a totally amphibious Jeep.
They ran a snorkel to the air intake, better seals on gas cap and oil cap, and greased the battery terminals over (or paraffined them) while putting a riser on the exhaust pipe.
It could cross some deep rivers (as long as the occupants and driver did not drown).
12/20/2016 1:46 PM
LBJ was a crap President. Sorry, I just don't buy it. Some things I liked about him in spite of his meandering leadership. He and McNamara just about guaranteed failure in Vietnam with their micromanaging the bombing of all outhouses.
12/20/2016 1:56 PM
His decisions were not that easy - we had a very tenuous relationship with a certain other Communist country that greatly limited the military actions he could take. For that matter, there was a third one that could have sent troops pouring in from the north. In hind sight, he probably could have bombed the entire country out of existence, and no other country would have done a thing about it, but back then, that was very uncertain.
Hey - I didn't want to insult a Texan in front of you two.
12/20/2016 2:05 PM
No problem, you can insult Democrats all you want to, especially ones from Texas.
12/20/2016 2:23 PM
I remember as a child that there were Democrats in Texas, and Democrats who ran on the Republican ticket since they missed the Democratic one. I take it that has changed quite a bit.
12/20/2016 2:39 PM
12/20/2016 2:43 PM
Looks like Pennsylvania - blue in a few stray counties and the big cities. Otherwise - Trump.
12/20/2016 2:44 PM
As Westman points out in #54, the map shows more red now than back then. In the old days, Texas was a blue state (before there was red and blue on the map), with Democrats in control just about everywhere south of Plainview.
There aren't so many cotton Democrats around any more, most of them would not recognize their party, and these days Republican ideals would fit their large agri-businesses. Populists rule the day this time in the R circle. This will be exceptionally good for Texas and for America.
12/20/2016 2:53 PM
Yeah - I always was confused by the southern and Texan Democrat when I was in high school and college - they seemed more like Republicans than Democrats, even back in the '60s. I think it was just a tradition dating back to the years after the Civil War.
12/20/2016 3:33 PM
Pretty much. Any more, it is not your father's Oldsmobile.
12/19/2016 3:27 AM
The temperature is limited by the boiling temperature of the contents at the ambient pressure. At sea level it is around 100degC for water, and a set of steam tables will show the temperature at different atmospheric pressures.
12/20/2016 6:31 AM
Sorry, but I think this design is unsafe in principle. Consider user 1, setting it for use as a steam spa. Shortly afterwards along comes user 2, only to spill boiling water on his hands when he is expecting only warm water. How are you going to prevent this happening?
12/20/2016 7:55 AM
If the "warm" water temperature setting is for e.g. making tea (see #16), I don't think peeps will be expecting to be able to wash their hands with it!
12/21/2016 11:08 AM
I didn't say wash hands, I said spill, as in accidentally. Tea-making water is not going to be as hot as on-going steam generation.
12/19/2016 12:10 AM
How much power your warm-water reservoir shouldn't be much. If the reservoir is well-insulated, maintaining it at temperature won't take much. Is the water consumed? Say, to make tea or something? Then it's a matter of how fast it's replenished and how fast you need to heat the incoming water. If the reservoir is open you'll need more power to keep it at temp. But a litre of water isn't much. I don't know about the steam requirements for facial units. Go to a shop that sells them and see what their power requirements are.
Is this what they/you are making? Some sort of steam-facial/hot water thingo?
12/19/2016 4:39 PM
If you make steam for a facial spa, I suppose you don't want to "superheat" that steam, otherwise it will be more than a facial "peel". People generally do not like when their face falls off the bone. Is this thing about the size of a vaporizer?
12/19/2016 11:27 PM
This is the new type of question.
A. Vague.
B. Mystery.
C. Guessing.
D. Your suggestion.
12/18/2016 10:40 PM
"How can I reduce or vary electrical power supplied to my unit?"
1. I'm guessing from your post's title that you mean 'power-supply unit'? It all depends on what the supply is expecting for input. Unless the power supply is designed to take a variable input voltage, typically it's expecting mains voltage within a certain tolerance and frequency. 105-130 VAC, 50-60 Hz for example.
2. Something like this, an interval timer?
12/18/2016 10:54 PM
Yes there are plenty of these devices....AC or DC? What is the voltage and amperage range? What sort of device? What would be the time on and off frequency and duration?
http://www.bkprecision.com/support/downloads/power-supply-guide.html
12/18/2016 11:07 PM
Its AC supply. 50 Hz frequency and 220 V.
Device is water heater or steamer.
On time may be 1 to 5 sec
Off time may be 1 to 5 sec
I may also need a device to switch off the heater after specific period, say 10min or 30 min. I guess there are some mechanical timers to do this job. But, then I also heard that its better to use some SCR to switch off the supply at some phase start or something
12/18/2016 11:20 PM
Switching that much amperage on and off so quickly would cook the contacts....contactors are usually rated by on and off cycles design life....you would blow through those life cycles in no time...What exactly are you trying to do?
12/18/2016 11:23 PM
It won't do the heaters any favors either.
12/18/2016 11:28 PM
Then what about controlling the mains power through some device as I mentioned earlier.
They must be doing that in commercial facial spa products
12/18/2016 11:37 PM
How much current are we switching? Use an interval timer to control a solid-state relay rated for the load and you're home free.
12/19/2016 4:43 PM
Go buy a facial spa, take it apart, and see what they are using. It might be a bi-metal contact strip, so that when it gets to temperature, it goes open circuit, although that does not seem particularly safe to be putting one's face near.
12/18/2016 11:31 PM
Heaters aren't typically reactive loads and solid-state relays sidestep the contacts problem anyway.
12/19/2016 3:04 AM
A trip to the local home improvements store is overdue; call it a fact-finding mission. Many of these stores stock all manner of home automation devices such as
  • light sensors that switch stuff on and off dependent on daylight
  • temperature sensors that switch stuff on and off dependent on ambient temperature and individual process temperatures
  • timers that switch stuff on and off dependent on time
  • presence detectors that switch stuff on and off dependent on room or building occupancy
  • remote-actuation devices that switch stuff on and off dependent on commands sent from a phartsmone over the internet
Some of this stuff plugs into a wall socket and the appliance plugs into the device.
Other stuff is suitable for fixed installation; if in doubt consult a qualified Electrician.
These stores have so many of these things that they sell them just to get rid of them, so building them is superfluous.
12/19/2016 5:11 AM
As others have said, at normal atmospheric temperature the water won't get any hotter than boiling point (about 100ºC) - just right for tea.
I don't understand why you need both a power control and a timer.
I suggest you look at temperature controllers (e.g.) or maybe a simmerstat. If you search around you should find one which will hold the water just simmering (rather than boiling violently).
You can almost certainly get away with "bang-bang" (on-off) control, and with a resistive load (the heating coil), mechanical relay type output will be OK.
12/19/2016 7:13 AM
You might also like to search for "dimmer controllers" or similar. While I'm not suggesting a light cotroller (Power rating probably too low) they do work a little like you describe, but by only passing a (variable) proportion of each source wave through to the load.
That device with a bypass switch for "full steam" seems something like you describe.
Now!! Can you please also understand that where I come from ANY device connected to mains MUST be
  • An approved device. (Not some home built prototype.)
  • Installed by a licenced elecrician. (Do you have such qualifications?)
Caution also:- most crude dimmer circuits do not pass recent regulations for electrical interference.
My real suggestion is that if you are a Mech Eng, then find an Elect Eng and respect their training. Just as I might develop a mechanical concept, but would then have the detail done and confirmed by a Mech Eng.
12/19/2016 9:36 AM
You are absolutely right!
I was going to do that anyway
But, I always believed that some homework wont harm you. And getting some expert advice will help me to put my case in better way.
There is no better place than CR4.
Thanks a lot for all the suggestions and ideas. Now, I know what to do and what to look for.
Re: Power Supply and Timer
12/19/2016 11:40 AM
Call an EE.
12/19/2016 4:36 PM
Without additional information about the type of voltage supply, it is really hard to answer your query.
If DC, you could perhaps look into "H" drives to achieve variable current supply that you control.
If DC, you will experience issues if you attempt to use a solid state relay, as it will fail to switch off once activated, typically. Use a physical solenoid relay (as is the relay on a car starter motor).
If AC, then various options are available including SCR, solid state chopper relay, physical relay, etc. On/off switch... depends on what you need it to do.
12/20/2016 11:25 AM
You/they should really consider a small electric batch heater for the hot water source then focus your attention on the steam source.
12/20/2016 11:27 AM
Good answer, as usual! Go mode, and blow mode.
12/20/2016 11:54 AM
Most kind of you, thanks!
12/20/2016 11:38 AM
Whether I should go for a dimmer or a SSR?
I searched on internet and they both seem to serve the purpose
What should be my criteria, if I want to choose between them?
such as cost, size, ease of control, accuracy, etc.
12/20/2016 11:45 AM
Cost and ease of incorporating into your device(s) should be two of the major concerns. The major concern is always electrical safety.
12/20/2016 6:51 PM
Careful! An SSR is just a Solid State Relay - all it can do is switch a supply on or off; it's the control circuit that matters (which could be identical to a dimmer control circuit).
In reply to #59
12/21/2016 12:36 PM
And SSr's do not switch off DC power very well at all, it needs that zero crossing to reset.
12/21/2016 12:40 PM
The OP did say the 'power supply' is the mains.
12/21/2016 3:40 PM
OK, my bad, I too am using a relay (solid-state) that is driven by a relay board, driven by an Arduino, to turn on/off a 12 VDC supply at an outlet (on my experiment, not on the wall) that is 120 VAC, thus I am also switching the "mains".
That part I totally get.
In reply to #63
12/21/2016 7:06 PM
DC switching SSRs are becoming more and more readily available these days (seems they usually have MOSFET outputs). Used to be hard to source and expensive - now well worth considering for switching tens of amps at tens of volts, which is tricky with electromech. relays (but SSRs are obvs. not suitable for safety applications!).
In reply to #64
12/21/2016 7:32 PM
Nope, never want to use a SSR in safety applications.
Years ago I worked on the driverless rapid transit system used at Duke University, North Carolina, between their North and South hospitals. Parts of the switching was done by special, fail-safe electromechanical relays of the kind used by the railroads. Connected to the relay armature was a big metal weight designed to pull it into a known state in case of power failure. Outrageously expensive but so are train crashes.
In reply to #64
12/27/2016 9:46 AM
John: do you happen to have some examples of the newer SSR's that might be of interest in pulsed DC applications I am interested in. For example, it is will known (found in the writings of Bokris of TAMU) that pulsed DC electrolysis of water is more efficient with higher gas production than constant current DC.
In reply to #66
12/27/2016 10:26 AM
Crydom make a range. The RS Components website is currently off-line, but there are more examples there.
In reply to #67
12/27/2016 11:14 AM
I went to the RS Component International web and it was up, but for North America, the only SSRs I found there were Crydom. Good links, thank you much.
Register to Reply 68 comments
Andrew Westman (14); James Stewart (16); JohnDG (5); Just an Engineer (1); lyn (3); pc (10); phph001 (2); Phys (7); PWSlack (2); ronc (1); SolarEagle (4); tonyhemet (1); wmerryall (2)
