Previous in Forum: What Are These? (I Really Have No Clue)   Next in Forum: Lots of Drones
13 comments
Good Answers: 94
High Temp Material
12/22/2016 4:41 AM
We have a small vacuum oven used for baking components prior to assembly in order to remove contaminants. This has worked OK for about 20 years but the company decided that the top support plate had to be replaced as it was asbestos & was becoming abraded, it was felt that this was a safety issue. This was particularly sensitive as one of the operators had a husband who died early this year from an asbestos related illness contracted long ago.
We replaced the top like for like with a sheet of Sindanyo but this fractured after a couple of thermal cycles. We then replaced it with another, thicker top from laminated mica, suggested by the supplier but this has started to crack & delaminate.
They are now suggesting a material called Zircar which I am not familiar with but seems to be another composite fibre board.
The oven cycles from ambient to 700°C & sits at temperature, usually overnight. The support needs to be thermally non-conductive & needs to take the weight of the oven. I don't know the weight exactly but you can pick it up with one hand (just). The top is around 550mm square.
Any suggestions for a suitable material?
Good Answers: 137
Re: High temp. material.
12/22/2016 4:57 AM
Could you make it out of 2 sheets of metal (strong enough to support the load) with insulating material between? Maybe mineral wool, or one of the materials you tried before might be OK if it didn't have to take the weight.
Good Answers: 94
12/22/2016 5:30 AM
What we are trying to avoid is conducting heat from the oven & surrounding heating element to the outside so we have been avoiding metals.
12/22/2016 9:36 AM
The outside of the oven is metal, right? The weight of the oven is supported through the metal structure of the oven, I would guess.
Affordable high temperature materials that are good thermal insulation are usually not very tough. If you can separate the task of support and insulation, it becomes much more simple.
One possible route would be a metal support that aligns with the metal frame of the oven. The center metal support under the nonmetallic part of the oven should be recessed or completely hollow. That space should be filled with an insulator, perhaps a firebrick or one of the earlier materials already tried. Some form of gasket will be needed so that this are sealed without the full weight of the oven being supported by the high temp insulator.
12/22/2016 5:20 AM
Aerogels?
Rockwool insulation over a substrate?
Re: High Temp Material
12/22/2016 8:02 AM
Maybe NASA has some shuttle tiles that they are not using anymore.
12/22/2016 9:09 AM
Many years ago Corning (I think it was) developed machinable ceramics. Other companies now make these materials (or buy the stock from a company like Corning). The machinable ceramics can withstand high temperatures, often have low thermal conductivity, and are usually chemically inert.
Here is just one company I found doing an internet search. You can find others - maybe a place close to your company that will work with you.
http://www.cotronics.com/vo/cotr/cm_machinable.htm
Good Answers: 94
12/22/2016 9:40 AM
We use similar material, they can be a bit brittle & tend to degrade with repeated temperature cycling.
12/22/2016 9:25 AM
You might give these guys a call:
Hi Temp Ceramic Adhesives - ellsworth.com‎
Adwww.ellsworth.com/HiTemp/Adhesives‎ Ceramic Adhesives from Sauereisen.
Hi Temp Heat Restance to 3000 F
They deal in high temperature "stuff" and may know of something you could use.
12/22/2016 9:44 AM
That Zircar has a much higher max temp. I'd give it a try as long as it's adequately supported underneath. As it seems to be intended more as an insulating panel, it may have low crush strength. Get some and give it a try.
Looks like you were running Sindanyo at its max temp. Probably why it didn't last.
Have you also considered something like alumina refractory tiles?
Good Answers: 94
12/22/2016 9:50 AM
We were pushing the Sindanyo to its limit. We will try the Zircar if we can't think of any better options. Alumina would probably work but is a bit expensive to have machined.
Good Answers: 73
12/22/2016 4:12 PM
Zircar is a ceramic fiber which is the best way to go. Do a search for ceramic fiber boards. They come in 2' by 4' by 1 or 2 inch thickness.
Pay attention to how your insulation is held in place. You may have to weld some stainless steel studs (threaded on the inside) to the case. You can also get wet ceramic fiber that hardens the first time it is heated, but it is a bit chunky and harder to work with. Fills holes very nicely though.
Stainless steel plate on the bottom to protect the insulation is also a good idea depending on what you are processing.
12/23/2016 12:34 AM
The only thing i can think of that will take the weight is the shelving used in ceramic kilns. My kiln fires to 1350degC. To keep the top surface cool to the touch add a layer of woven ceramic cloth. The woven cloth isn't as friable as the ceramic board.
Good Answers: 58
12/23/2016 3:36 PM
Try Durock, available at Lowes, Home Depot, etc. It's Class A fire rated. Not that difficult to cut or drill, stack it up to whatever thickness you need. Not expensive.
mike k
Register to Reply 13 comments
Andrew Westman (1); Codemaster (1); JIMRAT (1); lyn (1); mike k (1); Nigh (3); NotUrOrdinaryJoe (1); PWSlack (1); Rixter (1); truth is not a compromise (1); Usbport (1)
