Previous in Forum: GEN- SET CALLIBRATOR   Next in Forum: Worm Gear Calculations.
9 comments
boiler fusible plug failure
08/12/2007 1:43 PM
we like to understand various reasons for frequent failure of fusible plug in the steam boiler in the industry.
User-tagged by 5 users
Re: boiler fusible plug failure
08/13/2007 12:07 AM
Too much pressure, it sounds like.
08/13/2007 5:10 AM
The job of the fusible plug is to act as a final resort to poor boiler water level management and prevents the boiler from exploding.
As an illustration, on a steam railway locomotive a fusible plug is present as a fitting in the firebox crown plate. With good water level management (the job of the fire[wo]man) the fusible plug, which is exposed to the heat from the fire in the firebox, is kept close to the temperature of the water above it. If the water level drops low enough to expose the fusible plug to steam instead of water, the temperature of the plug will rise, the inner part will melt, and the contents of the boiler will very quickly vent via the firebox, a spectacular and very hazardous event that, should the crew survive, provoke demotion or dismissal. Were the fusible plug to be absent, the rising temperature from low water level would eventually cause the softening of the firebox crown plates, from which a catastrophic boiler failure can be expected with casual damage to most objects within a wide radius and destruction of the locomotive.
http://en.wikipedia.org/wiki/Boiler_explosion
Engineering Fields - Marine Engineering - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member
08/13/2007 6:39 AM
should the crew survive, The plug is there so that the crew will survive
Reset, Reset
08/13/2007 6:44 AM
Baling the fire out while the firebox is filling up with vented steam? Stuff that for a game of soldiers!
Sorry: "If the crew stays on the locomotive". Let's try that instead.
Good Answers: 18
08/13/2007 8:36 AM
Too much heat.
08/13/2007 8:44 AM
Andy Boilers does not need Fuse plug, water Level,Pressure Gauge, Vent valve,
Safety Valve,
Needs only MSV,Feed,Blowdown & Andy Boiler Device for all controls
cost Rs 2000 to 10000 on TPH
Lumpsum. Royalty 15 Lakhs, 100 each
Engg Design, 150 hp/1000 cc, 1600 hp/2400 cc F1; 600 kph MonoRail,Ferry,VLCC
08/13/2007 2:53 PM
In his eloquent answer, PWSlack illustrates a very important point. Your problem is not a problem with the fusible plug. It is a problem with proper maintenance of the water level system. As PWSlack points out; this is a safety issue.
The water level sensor and reporting instrument (even if it is only a glass sight gauge) are seriously out of tolerance and should be calibrated and adjusted as soon as possible before some unknowing mechanic attempts a "fix" and replaces the plug with something more substantial (the resulting explosion may eliminate your need for an answer from this forum).
intellectuals solve problems, geniuses prevent them ~ Einstein
08/14/2007 4:58 PM
Fuse plug, water Level,Pressure Gauge, Vent valve, Safety Valve,
08/14/2007 12:31 AM
Check fusible plug for quality of metal & improper filling.
Increase water level in the drum after careful study.(Provided your basic water management is alright.)
Anonymous Poster (1); appan (2); Bill (1); davah (1); mutantone (1); PWSlack (2); taejonkwando (1)
