Previous in Forum: Electrical Power   Next in Forum: MSP430 To Do The Night Light
12 comments
Embarrassing Question
01/16/2017 2:24 PM
Hey all
Im hoping someone can explain this
This is fairly embarrassing i don't remember why this is not working out
Simple RC circuit
We know the transfer function to be the following
Vout/Vin = (1)/(S*R*C+1)
Or if you want to rearrange it in the proper form you get.
(1/RC)/(S+1/RC)
Anyways. If you give this thing a step input you get a curve that looks like the following using matlab
Again no surprise. As the cap begins to block the voltage builds up as the current flow tends towards zero
No surprise here
So anyway here is what i can't remember.
Just for the hell of it, i was trying to take the laplace and do the inverse and plot it in math against time t without using the step command. Obviously i should get the same results
The inverse is easily found using the table of course
Now lets just take something simple
Say R = 1k and C = 1u
And plot the thing
You get something very different then what the step response should be
You clearly get a decay which is obviously not the case.
So what am i missing? Why when put back into time does the function not behave properly? or more likely, what am i doing wrong here?
This is what the plot looks like of the inverse in T
What am i doing wrong?
Thanks in advance for helping me fix my lost memory
Good Answers: 140
Re: Embarrassing question
01/16/2017 2:53 PM
Well... just off of the top of my head, if you expected the traces to be exact inverses of each other, you need to fix the scaling. Different from one plot to the next.
01/16/2017 2:58 PM
No no they should not be the inverse of each other they should be the EXACT same curve
They are the same function
The scaling is off simply because those are not the exact plots i just posted those picture so people could see what the general shape is
The top one is correct like we would expect.
The bottom one shows a decay for some reason and that is incorrect and i don't know why
Given the fact that the laplace inverse is correct
01/16/2017 3:44 PM
Anyone else?
I mean this is just an RC circuit lol i know there are some smart folks on here
01/16/2017 3:58 PM
Should you, or should you get an RC time constant capacitor discharge curve instead?
RC time constant discharge curve
It's been a while since I had to do the math but the charge and discharge curves are different. Isn't the inverse of a RC time constant charge curve the discharge curve?
01/16/2017 4:03 PM
yes of course they are different
But this has nothing to do with What I'm asking
My function is the step response of the circuit not the discharge
The only difference is one is laplace and on is in time t
These two functions are suppose to be identical
One is in s the other is in t
They should match up exact
The step response in t is just 1
So Vout_in_t = 1 * (Inverse Laplace of the function)
They should be identical
Good Answers: 116
01/16/2017 4:20 PM
The inverse you give is not the inverse of the transfer function * 1/s, where 1/s = the step function.
What you need is the inverse of [α /(s + α)]*1/s = α /[s(s + α)]
where α = 1/CR
According to my tables the laplace transform of 1 - exp(-αt) is α /[s(s + α)]
01/16/2017 4:29 PM
Im a moron
Your answer is not the reason mine is wrong but your answer reminded me of what i did wrong
The step function in matlab automatically multiples it by 1/s
When i do it in T i must multiply it manually.
For my time function i left out the 1/s
THANK YOU!
01/16/2017 5:02 PM
The dead giveaway is that the second plot starts out with charge already stored in the cap. Where did that charge come from? Certainly not the from the step function, so somewhere the step function must've gone AWOL, no?
I helps sometimes to step away from the mathematical representation and think about how the physical device actually works, apart from its abstract representation. When all else fails, derive it from first principles. That way you don't have remember anything.
01/17/2017 11:44 AM
Yes I knew it was wrong the second I saw it from intuition
Problem was my code per usual....
Thanks to everyone for jogging my memory
doesn't work so well when you forget to give it a 1/s input
Thanks again folks
01/17/2017 4:13 AM
All one has to remember is that for a first-order system, the response is within 1% of the new setpoint after 5 time constants.
Re: Embarrassing Question
01/17/2017 1:57 PM
You have to evaluate the functions over the same time limits?
you forgot a constant somewhere that transforms as 1-eX
Good Answers: 42
01/19/2017 4:37 AM
First of all-that has to remain between us- I hate Laplace- and the matlab also- since I am an old Power Electrical Engineer and the complex calculation and Microsoft Excel workbook is my usual way to solve a problem. Of course, nobody cares what a hate or like.
Second, since we have a lot of way to connect R and C let's take this one.
Now in summary, let's remember what I learned many years ago:
1) By definition the transformations are [ >>="it corresponds to"]:
d(f(t))/dt>>s*f(s) integral(f(t))>>f(s)/s k>>k/s f(t)>>f(s)
vcap=qcap/C vcap=integral(i(t))/C
2) The voltage drop on the above circuit is then:
vin=R*i(t)+integral(i)/C
By derivation :
dvin/dt=R*di/dt+i/C
Translating:
s*Vin=(s*R+1/C)*i(s) then:
i(s)=s*vin(s)/(s*R+1/C)
vout(s)=i(s)/C/s
vout(s)=vin(s)/(s*R+1/C)/C
Vin=constant[k] then vin(s)=Vin/s and:
vout(s)=Vin/(s^2*R*C+s) or:
vout(s)=Vin/(R*C)/(s^2+s/(R*C))
Let's put a=1/(R*C) then from table:
1/s/(s+a)>>(1-exp(-a*t))/a then finally:
vout(t)=Vin*(1-exp(-t/(R*C)) Q.E.D.
Julius
Register to Reply 12 comments
67model (1); 7anoter4 (1); Andrew Westman (1); jack of all trades (1); James Stewart (1); North of 60 (1); PWSlack (1); Rscott9399 (5)
