Previous in Forum: How do You Feel About the Economy Since the Election?   Next in Forum: China's Solar Power Capacity More Than Doubles in 2016
Which ASTM Specification Should be Followed While Forging a 316TI Fitting
02/06/2017 8:49 AM
Hello Folks,
i want to manufacture some Stainless Steel 316TI Fittings, where in i am required to forge the round bar, the specification for round bar is ASTM A479, when i checked the forging standard ASTM A182, i could not find 316TI in it, so now which spec shall i follow to make these fittings.
Thanks
Dhiraj Mehta
Ritinox Overseas (India)
Pathfinder Tags: 316Ti a182 a479 ASTM forging
Re: Which ASTM Specification Should be Following While Forging a 316TI Fitting
02/06/2017 10:03 AM
The spec(ASTM A182) is for SS which is 316TI which is SS with Ti as a stabilizer. Do you know the forging process?
I keep seeing people who have no knowledge or experience in a field attempting to produce a product which is beyond their capabilities.
Nothing intended but the forging of 316Ti requires a different process than Cs.
02/06/2017 12:22 PM
Ritinox overseas is an ISO 9001:2008 certified company and one of the renowned manufacturers of buttweld pipe fittings, compression tube fittings with and without ferrules, high pressure forged fittings and flanges. These items are manufactured in Stainless Steel, High Nickel Alloys, Alloy Steel, Duplex Steel and Carbon Steel.
Does his boss know where he gets his technical documentation?
He must be a friend of Coolyaar.
02/06/2017 3:53 PM
Explain your various standards in use and why you use them, and I will suggest to you a course of action.
Apparently, you need to learn more about Ti added alloy in forged fittings.
Re: Which ASTM Specification Should be Followed While Forging a 316TI Fitting
02/09/2017 2:29 AM
What makes you think you could comply with any such specification, no matter what it is?
Register to Reply 4 comments
James Stewart (1); lyn (1); ronc (1); Tornado (1)
