Previous in Forum: Use Your Hunting Camera Year-Round   Next in Forum: Engineering & Welding Software - DesignCalcs
Butterfly Valve Advantages, Shortcomings?
02/16/2017 1:02 AM
Butterfly valve advantages:
1) simple structure, small size, light weight, especially for large diameter valves.
2) compared to other types of the same caliber valve, the lowest price; especially stainless steel valves, because the fluid medium is not in contact with the valve body, so only the use of stainless steel valve plate, supplies province, low prices.
3) open and close quickly, small flow resistance.
4) can be used for media with suspended solids, depending on the strength of the sealing surface can also be used for powder and granular media.
5) can be applied to the fluid two-way opening and closing and regulation, regulating performance, and widely used.
6) Low pressure can achieve a good seal.
Butterfly valve Disadvantages:
1) flow adjustment range is not large, when the open up to 30%, the flow will be able to reach more than 95%.
2) due to the structure of the butterfly valve and sealing material restrictions, not for high temperature, high pressure piping system. General operating temperature below 300 °, PN40 below.
3) due to the valve structure of the restrictions, sealing performance relative to the ball valve is poor, so the sealing requirements are not very high places.
http://en.znqvalve.com/index.html
If you are interested in the product, you can contact
me at fanny@flange-valve.com
Pathfinder Tags: Butterfly valve advantages
Re: Butterfly valve advantages, shortcomings?
02/16/2017 1:24 AM
Pretty good summary. One item that deserves further mention, though, is the tendency of butterfly valves to drive themselves closed once you start to close them. They can slam shut, causing large hydraulic hammer.
02/16/2017 1:31 AM
Thank you
02/16/2017 4:12 AM
Disadvantage 4: the fasteners for the valve pass through the valve body, which is mounted between two flanges. Were there to be a need for the downstream piping to be taken down and altered, it is impractical to attempt isolation at the valve, and isolation needs to take place upstream of it instead.
Is this posting actually a thinly-veiled commercial advertisement?
02/16/2017 8:14 AM
No, its not even thinly veiled, (bottom of post)... but at least it gave some attributes.
And because of that, I'm holding off on reporting it. But it does belong in the commercial space.
**REPORTED**
02/17/2017 8:01 PM
The next will be corrected, thank you for the tips
codi-valves (2); phoenix911 (1); PWSlack (1); Tornado (1)
