Previous in Forum: Effect of Power Factor Correction in Fuel Consumption   Next in Forum: Automatic Transfer Switch
13 comments
Definition of Terms
04/22/2017 12:00 AM
I was speaking with an experienced electrician that was working on HVDC transmission switch gear for some wind turbines. Since I know very little about HV transmission I was asking some questions about the workings. We were discussing coronas and lightning and several topics on HV power lines. But he had mentioned a few terms which i have not been able to find anything on. Not knowing the terminology and only a smattering of the process I am certain I did not get the complete translation correct and we only spoke briefly but remembered as best i could so I could research this further.
1. He said when you energized a line you could see an 'A-harp' (just spelling it as I heard it -it could be some other spelling) coming down the line..
2. 'Valve hall' or valve haul- (again as I heard it) described as a room or chamber that was where the power came in and was cleaned up or filtered and if the potential was lower or higher it was somehow matched up with what potential was to go out. He said it was a room that once the station was powered up no one ever went inside again.
3. Osmotic or osmotics driver. I had him spell that one for me because i had never heard this one ever. I don't remember his description of what this was but it had something to do with the operation of the valve hall I think.
He was a super interesting man and he went over so many things I know I missed much but I remembered these and that when he was younger he was dropped from a helicopter onto the HV lines and did repairs on the towers/insulators which I had seen done on a NatGeo documentary or such.
So does anyone know what these things could be?
deanpavil
Re: definition of terms
04/22/2017 12:57 AM
It would be interesting if you could reflect these questions back to him for spelling confirmations and answers.
04/22/2017 1:36 AM
04/22/2017 6:09 AM
Valve Hall
Osmotic
Sorry, could not find anything on "A-Harp".
04/22/2017 12:11 PM
I found a B-harp....
04/22/2017 3:52 PM
Again thanks for the laugh, I did try finding an aardvark playing a harp with no luck, I wonder if he said "an arc"?? G.A. from me.....
04/22/2017 5:37 PM
Maybe he meant this kind of harp....
04/24/2017 11:33 AM
Other worldy sounds of a power line
Is this what was being referred to?
Re: Definition of Terms
04/22/2017 10:13 AM
There's a thing called Google, which answers any question one throws at it. It's a good first stop.
04/22/2017 11:08 PM
Others seem to have pointed to meanings of words you mention, except to A HARP in a serious way.
I cannot help either but to say that it is possibly a slang term or acronym referring to the fact that when transmission lines are first energised, they so not suddenly and cleanly get to the specified AC signal levels immediately.
All electrical circuits have an inductive and capacitive component in them and so delay and some ringing around the target value is likely.
Transformers do not fire up immediately for example. They take from a few to thousands of cycles to saturate and come into equilibrium and generate harmonics in the process.
I could not imagine that other than a pulse of some sort would propagate quickly, but at a finite speed down the line that was being energised.
The term a HARP could, for example, be short for "a Harmonic and Reaction Pulse"
Good Answers: 804
04/23/2017 2:26 AM
HV transmission lines will make a sound based on their being induced to vibrate at their natural frequency if not dampened. When that happens, it's referred to as a "harp effect". We mostly don't hear it specifically because it's a known phenomenon now and dampening is built in to the transmission towers and supports. Occasionally however the standard dampening doesn't work and weights are added to the wires mid span. I learned this from a friend in the T&D side of the industry after asking him about some weights I observed.
04/23/2017 5:03 AM
Valve Hall: this is a water cooled array of thyristors hung from roof beams. the valve can weigh 20-30 tonnes. Most valve nowadays are using light to produce an electrical signal. The light being converted to produce electricity via light sensitive semi condictor segments.
The valve cooling water is pure water and is an insulator for the valve and cools the valve when the converter station is under load.Large water purification systems are installed to ensure the water does not conduct while cooling valves.
Valve are hung from the valve hall roof to be earth quake proof.
A Harp. Many names for the phenomenon of seeing a voltage as a blue haze progressing along a conductor when first energised. This is also common on AC lines under certain atmospheric conditions. On DC lines there is a sharp spike in voltage then it settles to the input voltage of say 400-600kV. It can be summed up, (imagined), as a single huge wave approaching a beech and the following waves being the normal flow thereafter.
The voltage must not exceed 1.5 times its normal value and the voltage peak must not last longer than 1second, so to reduce this spike shunt reactors are installed
05/13/2017 11:13 PM
By "a-harp" he may have been referring to the sound and/or visual effect similar to that produced by an instrument called an aolean harp, a special kind of harp that is literally "played" by the wind.
From the wiki: "The effect can sometimes be observed in overhead utility lines, fast enough to be heard or slow enough to be seen."
These vibrations can become of such magnitude that they can put undue stress on lines, and so you'll see a device called a Stockbridge Damper attached to (typically high-tension) suppress these vibrations.
05/14/2017 12:36 AM
aeolean, not aolean
Register to Reply 13 comments
Andrew Westman (2); IQ (1); James Stewart (1); JPool (2); JRaef (1); PWSlack (1); SolarEagle (3); Tornado (1); TrevorM (1)
