Previous in Forum: Juicero - Poster Child for Silicon Valley Excess   Next in Forum: Cell Phone IDs and CCTV
16 comments
The Engineer
Good Answers: 129
Recycled Plastic Makes Asphalt Roads 60% Stronger
04/27/2017 9:56 AM
I came across this article and thought I'd pass it along. I'm impressed by such a simple solution producing such impressive results. I know here in the Northeast we could use stronger, longer lasting asphalt.
U.K. startup uses recycled plastic to build stronger roads
We’ve seen the birth of futuristic solar roads and even a return to retro gravel roads, but now there’s a new player on the street: recycled plastic. British engineer Toby McCartney has devised an innovative process to replace much of the crude oil-based asphalt in pavement with tiny pellets of plastic created from recyclable bottles. The result is a street that’s 60 percent stronger than traditional roadways, 10 times longer-lasting, and a heck of a lot better for the environment, claims McCartney’s company MacRebur.
McCartney first conceived of the idea after getting fed up with the potholes in the roads near his house and remembering how he’d seen people fill potholes in India by filling them with plastic trash and melting it into place. Typical roads are made of about 90 percent rock and sand with 10 percent bitumen. MacRebur’s product essentially bulks up the bitumen with recycled waste plastic, so the roads are stronger and less of the oil product is required to bind together rocks. McCartney paved his own driveway using the plastics-augmented process, and the English county of Cumbria has already adopted it for new public roadways.
Article Found Here.
Re: Recycled Plastic Makes Asphalt Roads 60% Stronger
04/27/2017 1:05 PM
Makes perfect sense.
Years ago (before there was an Internet) I read an article about pavement being mixed with ground-up tyres. This seems like a natural extension of that idea. Wonder why it took so long...
04/27/2017 2:26 PM
It is a waste of perfectly good fuel, but yes, you can do that.
BTW whose as-phalt is that?
Good Answers: 444
04/27/2017 2:59 PM
NYC took a different approach and used ground up glass mixed in with the aggregate, as have other jurisdictions.
The Engineer
Good Answers: 129
04/27/2017 4:35 PM
I'd like to see this stuff adopted soon (if it works as well as they claim). There is a pothole at the end of our driveway that keeps coming back every year. Would love to see the fix last longer than 12 months.
Good Answers: 18
04/27/2017 5:59 PM
What about the potential for general paving?
04/27/2017 10:00 PM
When I lived near Boston I noticed a pothole that stretched from Revere south to Hyannisport.
The Engineer
Good Answers: 129
04/28/2017 6:17 AM
04/28/2017 9:35 AM
You mean from the Tobin Bridge, down the Southeast Expressway and Rte 3?
My friend who used to commute from Marshfield to Boston on Rte 3 called it the Trail of Tears.
04/28/2017 9:38 AM
Oh that part. Oh yes, that's the famed pothole-within-a-pothole section. They're recursive, you see. You curse and re-curse all the way home.
04/28/2017 9:22 AM
They have had plastic membrane underlayment for pavement (Phillips) since the late 1980's I think, some places have not implemented use, however, but it would stop the recurrence of pot holes, since it has to do with how much water gets coupled into the dirt below the asphalt, then softens the soil to pliable mush. Isn't plasticity a wonderful thing?
One thing you might try, is lose some weight, since your moniker portrait seems quite portly. (Just kidding).
Although, in Texas, most pot holes are caused either by pot guts, or by fat arses.
04/28/2017 10:18 AM
04/28/2017 10:28 AM
ROFLMAO!!! Make it so #1!
04/28/2017 8:40 PM
I think one of the biggest hurdles was all the metal found in tires due to the countless variations on how a steel belted tire plus it typically steel wire/cable reinforced lip is made.
In many tires that steel reinforcement around the lip is solid wire and not the fine flexible stuff the belting is made from which means if it gets into a roadway you have a huge potential for producing flat tires.
They ran into that problem when they experimented with using old asphalt roofing shingles and such materials in roadways and found out that many roofs were made with aluminum nails and staples that were not sorted out by the magnetic separators they used to get the steel one out so the roads the experimented with that on lead to countless flat tires for their efforts.
Also to reduce a tire down to asphalt aggregate size bits takes a considerable amount of energy for the volumes produced.
Some years ago a guy I worked for one summer (wanna be engineer with little basic sense and even less engineering skills) went about building a huge tire shredder machine with the intent to corner the market in our region on shredding tires.
Fatal flaws as I was told, was that to make his machine work it needed a huge engine so he got a huge boat engine rail freighted in from who knows where on the coast which between the cost of the engine, the work and money in getting it here plus making it work put the operation way over budget.
Then to top it off apparently he did not factor in just how much fuel a several thousand HP engine burns. finding out one that size can burn a semi tanker truckload and then some a day, Vs one a week, was a real kick in the nuts and any hope in having an actual profit margin that would pay for the project in any rational time frame.
04/28/2017 8:52 PM
It was some time ago when steel-belted tyres weren't as common and so they had plenty of old, steel-less tyres to work with. I don't know what the fraction is today but I reckon most are steel-belted these days. Still, the concept of mixing recycled plastics in asphalt isn't all that much different in principle. I mentioned the tyres because it's basically the same idea, and so I'm wondering why it took them so long. It's a great idea if it works.
04/27/2017 9:30 PM
It would definitely be a booster for plastic recycling operations nationwide.
Having a customer that is not fussy about how clean or well sorted the plastic is would make things way more cost effective to work with.
04/29/2017 4:14 PM
Recycled bottles can be converted into textile fiber, fruit packaging, strapping, and many other uses, including more bottles, all replacing new material (a key aim of recycling). Don't forget economics: prices for recycled plastics have dropped in accord with lower petroleum prices, but still are more than road-builders will be able to pay. Cities and counties with crumbling roads often have minimal funds to fix them, and residents are reluctant to pay more in gas or other tax to provide this money. Are there different grades of asphalt? I suspect airport runways use longer-lasting grades. Is there a road-builder here who can add a professional comment?
Register to Reply 16 comments
agua_doc (1); Andrew Westman (5); Bayes (2); Brave Sir Robin (1); Griffex (1); James Stewart (3); RAMConsult (1); tcmtech (2)
