I need to connect a 220v / 25000 btu Air Conditioner with a 30" / 3 prong wire to a generator outlet, 220v circuit.
I am not sure what the amps are for the AC. One side of the plug has horizontal flat blade, one vertical flat blade and one round (ground) prong.
- How far can I run a 12/3 wire ?
- How far could I run a 10/3 wire?
- What do I do with the nuetral wire connection on the 4 prong male plug that goes into the generator?
The generator has a 4 space opening and has written in the manual " REMA 14 30."
Thank you.
