For your application of injection moulding the lubricant are widely used in all polymer industries, the contact details given below is of the manufacturer of speciality lubricants. This manufacturer is known for the excellant tailor made speciality lubricants for the companies with special appliaction and as per their requirement.
Are you sure you are not talking about transfer molding. Thermo-set plastics are usually not injection molded unless you are talking about new specialized machines just for the purpose. Chances are if you need lubricant on such a mold then there is a problem with the mold, either draft, polish or ejection.
Men are like steel, if they lose their temper they are worthless.
You are right , I am using a new specialized machine for the injection moulding of epoxy. I contact many people to get a lubricant for this , but nobody could suggest one.
I've been injection molding epoxy for about 25 years. A lubricant for the epoxy really depends on the epoxy type. Calcium Sterates are pretty good for anhydrides (avoid zinc sterates, they will change the reaction speed) and powdered carnuba wax is great for novolac types.
