Previous in Forum: Ultra-thin Camera Creates Images Without Lenses   Next in Forum: Concrete Erosion
A 100-Year-Old Physics Problem Has Been Solved
06/24/2017 5:47 PM
In 1914, K. S. Johnson introduced the concept of Q factor. The length of time a signal can be stored in a resonator is inversely proportional to the bandwidth. A high Q resonator can store narrow band energy for a long period of time, a low Q resonator has a larger bandwidth but can store energy for a shorter time. Now it appears this is not always true:
This is a wave-interference and resonant energy transfer from one source to another distant source or object, pertaining to the fundamental concept of resonances. Credit: EPFL - Bionanophotonic Systems Laboratory
"Researchers have found a way around what was considered a fundamental limitation of physics for over 100 years. They were able to conceive resonant systems that can store electromagnetic waves over a long period of time while maintaining a broad bandwidth. Their study opens up a number of doors, particularly in telecommunications."
More
https://www.sciencedaily.com/releases/2017/06/170622143058.htm
https://en.wikipedia.org/wiki/Resonance
Re: A 100-year-old physics problem has been solved
06/25/2017 10:00 AM
If this research stands up to scrutiny then this will certainly be a phenomenal result with possible impacts in many disciplines. This reminds me Bob Shaw's "slow glass" from his short story Light of Other Days. It also reminds me of that brief "faster than light" false discovery at CERN awhile back.
I looked at several different links on this report but they all seem to refer back to the exact same preliminary announcement. I'm also a little apprehensive since they all say that this was conceived and not a measured experiment. Fiction authors have been able to conceive all sorts of fantasies for millennia. If anyone finds more data on this report I'd love to read it. {This is exactly why I see a possible repeat of the above CERN incident.}
06/25/2017 8:03 PM
My simplistic understanding is that a resonator has a lot of energy bouncing around inside. It could be magnetic fields and electric fields in an RLC circuit, light in a Fabry-Perot cavity, sound in an organ pipe, whatever. A little bit leaks out. The less that leaks out, the higher the Q.
A sine wave of infinite length has zero bandwidth. A shorter piece of a sine wave has a wider bandwidth. The shorter the "coherence length", the wider the bandwidth. In a low-Q resonator, a sine wave signal escapes sooner, has a shorter coherence length and a wider bandwidth. This is basic Fourier analysis.
There are other ways than using a resonator to store a signal that obviously violate the Lorentz time-bandwidth reciprocity criteria. A delay line (electrical, acoustical, optical, etc) can store a signal with a bandwidth that does not depend on the delay.
I guess it depends in this case whether the device is a resonator or something else.
Re: A 100-Year-Old Physics Problem Has Been Solved
06/25/2017 11:49 PM
Show me some experimental confirmation, and then I'll be interested!
06/26/2017 9:43 AM
When he said the " Q " factor, I thought he meant this :
06/26/2017 11:51 AM
I see this as a big deal firstly in telecommunication.
It may play a role also in laser power amplification, and in some other fields, including detection of light signals that are so low they are in the noise limit.
06/26/2017 12:29 PM
That latter sounds as much like astronomy as communication...
06/26/2017 1:28 PM
OK, I left off astronomy, but in that field, one had best know how to dig those signals "out of the dirt".
Register to Reply 7 comments
dkwarner (2); James Stewart (2); redfred (1); Rixter (1); tonyhemet (1)
