Previous in Forum: The Center of Cosmic Energy   Next in Forum: ultraviolet images.
Good Answers: 19
What causes pressure in an noncompressible fluid?
08/24/2007 12:55 PM
Hi friends. I've asked this question to about 15 or so scientists all over the world and have many different answers, only one matching my own, and virtually none matching the other. Who >> PhD fluid mechanics professors, developers of pipeline hydraulic modelling software, PhD chief engineers of pump companies, double PhD Mechanical Engineering Science professors or staff at laboratories, my mother-in-law . . . none have the same answers . . . . . so now I ask you.
First, I know fluids are compressible so this should eliminate 30 replies telling me this known fact, so lets assume a pipe theoretically full of water (or whatever fluid you wish to put in your virtual model) without any air bubbles, blocked on one end and a PD pump on the other (similar to a hydrostatic test of a length of pipe laying on a shop floor). Once I begin to increase the pressure with the PD pump, what is the pressure mechanism occurring at molecular level to cause the pressure to increase in the pipe? This is not a question about what the pump is doing and how the pump is doing it, but what is taking place inside the pipe itself. Keep in mind before answering I'll likely ask you "Why" 5 times so ask yourself "why" a few times to your answer until we arrive at the root mechanism for pressure rise. This is for a class I teach on pumps and pipelines and I have two professors (40+ years experience each) who disagree with what I put in my class for this theory, and those two professors don't agree with each other at all. Only one person in the world agreed on my theory, a retired chief technology engineer of a major pump supplier. Thanks in advance for a reply. I'll share my theory I use in my class after I read some replies. George (willing to learn a thing or two here)
Re: What causes pressure in an noncompressible fluid?
09/01/2007 2:58 AM
I think you now know why they say there are those that teach and those that can do. Fluidics is my profession, strong emphasis on hydraulic systems.
When you look at the micro instead of the macro, you limit your horizon. There is only ONE answer for pressure in a system: Resistance to flow. What happens to the molecules, I could care less. I know, but it serves no purpose in day to day design and troubleshooting issues, which is 99.999% of all applications. The remaining percent is for dreamers.
Every time I get a novice to ride herd on in my profession, I always have to "undue" what was taught in school. A prime example is that it is believed that a pressure wand delivers 5000 PSI force to the object being cleaned. Not in this life. The pressure, once it leaves the containment of the hose or tubing is atmospheric. You are then dealing with velocity. to quantify the issue, take a sledge hammer and use 5000 lbs force to hit the side of your car. Force is force, water, steel, whatever. If you hit the side of your car with 5000 lbs force, I'll guarantee you it will dent the hell out of it.
So, what causes pressure in a "non-compressable" Fluid? First of all, fluid is compressable. You are putting a mechanical load on fluid, and limiting its flow path to achieve pressure. Any other answer is just blowing smoke up somebodies ass.
Good Answers: 59
#100
In reply to #99
09/01/2007 7:05 AM
How the blazes can you name yourself as curious? In any case, the question should first be answered - politely - as has been done, that there is no such thing as an incompressible fluid. Then, although it should certainly not be micro at the expense of macro, understanding what is going on at the micro level can be helpful, particulately (sic) when it comes to momentum (so-called pressure) washers. By your statement here, I think you are applying "undue pressure" to be ignorant.
And it is more than possible to apply a 5000 pound force to the side of your car without making a dent - in fact, the the typical force on the side of a car is in the order of 2000 pounds/sq.ft.
Good Answers: 247
#101
In reply to #100
09/01/2007 11:49 AM
I can verify what you are saying. I've just finished constructing a proof-of-concept prototype of a small vehicle, and I've subjected at least one side of that vehicle to an incredible 50,000 pounds of force! The vehicle is still under test, and has been subjected to this force for a long time... but still, not a scratch.*
To put that into perspective, consider that a solid aluminum bar of aircraft grade 6061 T6 aluminum has a tensile strength of just 45,000 psi!
* You may ask: "Why such brutal test conditions?" Well, think of the occupants. What if this 50,000 pound force were applied directly to them?
Good Answers: 59
#104
In reply to #101
09/01/2007 1:34 PM
Depending on the application, presumably there's some level at which you'd prefer the car to distort rather than accelerating bodily? I guess an acceleration of 10gn is OK for a short time is fine, but at what point does that change to KO?
Good Answers: 247
#106
In reply to #104
09/01/2007 4:03 PM
Under the present test condition, I have been unable to measure any appreciable distortion. I mentioned 50,000 pounds on one side of the car. There is actually a similar force on the other side, and a little less on both the bottom and top -- for a total of over 150,000 lbs. Then, as if this were not enough, inside the car, a similar amount of force is pushing outward!!!
I must have nerves of steel to be performing this experiment right in my own garage!
To go to the next step, getting all that force to act in the same direction, so as to accelerate this vehicle (which weighs less than 1000 lb with me in it) will be tricky. I don't think I'll be the test driver, as I fear the KO.
From this photo, you can probably see how the top and bottom forces might be lower than the side forces. I took this when the thing got loose from my garage and found its way to my front yard.
Good Answers: 59
#111
In reply to #106
09/02/2007 5:08 AM
I'd assumed opposing forces for the test, otherwise you'd be confirming Jorrie's relativity articles within a few weeks...
My thought was in connection with your "protection of the occupants" - with what appears to be a lightish (~1000lb??) vehicle and a 50k withstand force per side, the whole thing could accelerate at 50/m/s/s (5gn) without distorting. I'd be watching out for whiplash at the very least.
Good Answers: 19
#108
In reply to #99
title noncompressible fluid?
09/01/2007 6:15 PM
Hi Curious,
Have a look at # 67 and you'll see why I titled this the way I did . . . . . . guess it didn't work. Ha.
Fluidics? Cool. Interesting stuff. I'd like to pick your brain for a year or three.
OK, back to practical and non-practical discussions. The purpose of this post was to learn if my answer, and graphic depiction, to the question of "What causes pressure in a liquid pipeline" needed tuning for the intended purpose as well as to educate me, a full time project of Steve S., Ken, Del, Physicist, Europium and others.
How would you have answered, simply, in layman terms, where the person asking (who is a mechanical engineer and boss of a technology group) would not have replied "Yes I know that, but I want to know what is occurring at molecular levels."
Answers of:
* Resistance to flow
* The head capacity of a centrifugal pump converting velocity energy to pressure energy
* The specific gravity of the fluid compared with the available head capacity of the pump
* Elastic containment vessel
. . . bla bla bla
would not have answered his question. Ask 6 people and you'll get 8 answers.
Engineering Fields - Piping Design Engineering - Environmental Contractor United States - Member - Born, raised and proud to be Texan Safety - Hazmat - New Member
#102
09/01/2007 12:09 PM
Oh no........... I have a piping system hydrostatic test next week. Now that I've read this I'm sure to have nightmares.
Believe none of what you hear......and only half of what you see.
Good Answers: 19
#103
In reply to #102
09/01/2007 1:14 PM
Be sure to use surfactant ! Hey, just print all this and hand it to the vendor and say here is the test plan.
#105
In reply to #103
09/01/2007 1:48 PM
Petro,
It's even better than the vendors. I have a double set of witnessing engineering consulting firms I could hand this thread to. By the time they got through flashing 1's & O's the test would be done.
Good Answers: 19
#113
In reply to #105
Hydro Text HyJinx
09/02/2007 11:02 AM
Ah ha . . . you are the vendor. As a former vendor myself linking miles of pipe all over the shop floor to test, we NEVER passed up an opportunity to jack with the inspectors. And heaven help the ego toting pump inspectors (like me) when we did a pump case hydro. Some proven silliness:
1.0 -- Go get a busted gauge with no needle and paint one on the face and tell them "Welcome, we got 'er pumped up and she's been holding for 6 hours before ya got here . . . come look". Of course, you need one end of the pipe open for extra fun.
2.0 -- If it leaks, tell 'em you are now checking the outside of the pipe where flow it greatest . . . you know . . to give 'em a fair test inside and outside the pipe.
3.0 -- Lastly, pour several puddles near the flanges before they arrive and have empty tubes of Bar's leak scattered about.
For pump case hydros:
4.0 -- Go to Sam's Club and buy 3 of those little kid swimming pool snorkel kits and when the gurus show up, hand 'em out.
5.0 -- Here is a slide below from my high energy pump class. Show up dressed like this soaking wet when you greet them.
#109
09/01/2007 9:16 PM
Petro, In addition to your slides you may show an alcohol-in-glass thermometer. The "system" is closed and if energy is added by heating the bulb the vapor pressure of the fluid exerts pressure and the fluid rises in the stem to indicate a rise in temperature.
Likewise, if a simple bourdon tube measuring PSIG is capped off at sea level when the atmospheric pressue is 14.7 PSIA the gauge reads 0.0 If the barometer falls the gauge reads below zero, etc.
If you put some alcohol in the base of the gauge and cap it off you just made a thermometer, which looks an awful lot like your 1st slide, at no flow.
Although simple training aids, everyone will at least see the effects if not the reason for your question.
Good Answers: 19
#110
In reply to #109
09/01/2007 10:04 PM
Hey . . I have one of those curly cue colored alcohol glass bulbs heated by my hand sitting on my desk. Good conversation piece. I tell people I boil the fluid with my sexy personality and hot hand !
Anonymous Poster (13); aurizon (4); Blink (13); curious123 (1); DaveB (1); double_j_b (1); Hendrik (1); Hottech (4); jdretired (1); jrpeck (1); MACA (1); Moto (1); Pepper (2); PetroPower (17); Physicist? (11); PWSlack (1); Self Thinker (2); semi-retired designer (1); Sharkybaba (1); slong (1); StephanChE (1); Steve S. (10); Stirling Stan (3); TexasCharley (4); user-deleted-1105 (8); user-deleted-13 (1); user-deleted-5 (8)
