Previous in Forum: Gas Tanks   Next in Forum: Forklift Problems
None
08/28/2007 8:45 PM
I am looking for the most powerful electric water pump (not over 4 horse power) on the market
Gals per minute times PSI
Re: None
08/28/2007 9:19 PM
The most powerful pump that is not over 4 hp would be a 4hp pump--next question please
Good Answers: 19
Re: None
08/29/2007 7:56 PM
Ah, but my salesman from ABC pump co sez that his 4 HP pump is more powerful than the 4 HP pump that the XYZ pump salesman is trying to sell.
Which pump would you recommend?
Re: None
08/29/2007 11:37 PM
Obviously I would buy the one which does not 'suck'
Re: None
08/31/2007 10:08 PM
Your logic is unbelievable but you didn't answer my question.
Gwin
Good Answers: 19
Re: None
08/31/2007 10:27 PM
OK, we know you want an electric motor, not to exceed 4 HP, and "the most powerful".
Do you know what flow rate you would like? What pressure or head?
Do you want a piston, centrifugal, gear, or progressive cavity pump?
What motor speed? 900, 1200, 1800, or 3600 RPM?
Do you want a submersible or piped suction? Flooded suction or self priming?
Are you pumping clear water, sewage, gas, diesel fuel, acid, or some exotic liquid?
Provide some detail of what you are trying to do or solve, and you will be surprised at the advice you will get. If you leave too much to our imagination, well no telling what you will get.
Re: None
09/01/2007 11:06 AM
Ried:
Thanks for the reply. Maybe as soon as I get through the nones and the thread I will solve your webb site.
I am trying to find a three horse power electric pump or maybe a four horse power clear water pump.
I desire maximum flow rate (gals per minute times PSI).
I want the pump, regardless of type, that gives me maximum gals per minute times PSI.
Motor speed, you tell me.
I want to suck fresh water out of a tank through several feet of hose or PVC and run it out the other side through several feet of hose.
I will be attending a World War II reunion 9/7 through 9/17.
Yours truly
Gwin
Good Answers: 97
Re: None
08/30/2007 7:11 AM
It is a bit of an anomaly. What you require is the most efficient 4 hp pump)
The selection will depend on the setup. ie head or flow requirements.
Please give more information.
If you need to compare your 4 hp to the 4hp of your neighbour you need to compare the duty points.
Register to Reply 7 comments
Anonymous Poster (2); Hendrik (1); Ried (2); Ross N. Gwin (2)
You might be interested in: IP Cores, Power Take-offs (PTO), Industrial Magnets
