My landlord let a friend move his bus into the yard, a 1978 MCI, 8v-71 Detroit etc., and while attaching a battery charger he said it sparked a " lot". When I checked the battery's, 2 -12v. in series, I find one of them has it's polarity reversed. Put a volt meter on it correctly it reads negative volts, attach voltmeter reversed ,red to neg. black to pos. it reads normal voltage. Did he cause the battery to change polarity? They had been hooked up in series when he drove the bus here, and I moved it and it started and ran great. Whats up? Thanks!
