Previous in Forum: USB Problem   Next in Forum: outlook is syncronozing folders
Questions About Bus Signals
09/05/2007 10:26 PM
hi.. may i know the sequence of signals that occurs on the address bus, control bus and the data bus when the microprocesor reads an instruction from the memory..
ty^^
Re: Questions About Bus Signals
09/06/2007 11:56 PM
ty^^ That will fill a medium book. Intel put out a good one on the 386x process and code that is still relevant for 32bit systems. Sorry I don't remember the name but it had 386 in the title.
Try the web at Intel. They used to have extensive files on such for the public.
Brad
09/07/2007 11:05 PM
actually its for the 8086 microprocessor..
09/07/2007 11:32 PM
I believe you are correct. Only ten years Learned so much and maybe forgot more.
Thanks you wouldn't have an ISBN by chance?
Brad
09/07/2007 9:55 AM
I would look at the data sheet for a simple micro such as a Z80 8 bit not an 8080 as that uses a multiplex bus...
Basically the sequence is simply, set up pattern on the address bus then read data on the data bus, the control bus is just used to enable chips, read interrupts, etc...
John.
09/07/2007 11:18 AM
I should have thought of that, much easier to learn that way. I learned it the other way around due to work.
Brad
Anonymous Poster (1); Electroman (1); U V (3)
