Previous in Forum: ETAP Synchronous Generator Inertial Response   Next in Forum: VFD Chokes are Choking Me Out!
To Stop or Not to Stop, a CNC Magazine at Position for Tool Change
03/06/2018 4:59 AM
Kindly, we are running the below cnc machine, after finishing a control and servodrives upgrade.
But, we are having some problems to stop the tool magazine at the exact position for tool change.
It is rotated by an hydraulic motor, which is controlled by hydraulic valves, making it very difficult to control the stoppage position.
Have you seen any cnc tool change similar to this one?
Any recommendations? ideas?
MAZAK AJV-18N CNC Vertical Machining Center
http://www.gaec.com/catalog/machines/k13587.htm
Yamazaki AJV18N
https://www.youtube.com/results?sear...amazaki+AJV18N
(2nd 3rd ... videos)
index motor (hydraulic)
EIS 160-2PC-2AH0-LL
valve
SL-G01-A3X-GRT-C1-9320B
valve
SL-G01-C5-GR-C1-9320B
...anything that can go wrong will go wrong...
Re: to stop or not to stop, a cnc magazine at position for tool change
03/06/2018 5:01 AM
  1. As there is a <...we...>, what is the consensus of this group?
  2. What did the equipment manufacturer say during recent telephone calls on the topic?
The forum cannot know these things until they are stated.
03/06/2018 6:22 AM
Sounds like you could use a detent mechanism to stop it at the correct position.
Good Answers: 73
03/07/2018 12:30 PM
I found that such mechanisms add to the wear and tear substantially. There are special servo motors that have 615,000 steps or so per rotation. Kind of expensive but it out performs any detent device.
Re: To stop or not to stop, a cnc magazine at position for tool change
03/06/2018 9:24 AM
Register to Reply 4 comments
JPool (1); NotUrOrdinaryJoe (1); PWSlack (1); SolarEagle (1)
