Previous in Forum: SOS Call Before Factory Rebooting Phone   Next in Forum: Project GRACE (Gravity Recovery and Climate Experiment) Data Usage
26 comments
The Engineer
Good Answers: 129
Observing a Star from 9 Billion Lightyears Away
04/03/2018 8:40 AM
I found this article interesting. Basically, a large galaxy (B) passed in front of another galaxy (A) and through gravitational lensing, a star from (A) could be observed many billions of lightyears away. However, it was still too far for us to observe. It took a third galaxy (C) to pass in front of (B) and lens the star from (A) again. Thus astronomers from Earth in Galaxy (D) could observe the star from (A), which was 9 billion lightyears away.
What I found fascinating about this article is the four galaxies needed to line up in space-time, not just space at the same time. In other words, it took several billion years for the light from the star in (A) to reach (B) and then several more billion years for the lensed image in (B) to reach (C) and then several more billion years for the lensed image in (C) to reach (D). Given the vastness of space, and the fact all of these galaxies are moving, this is not an easy feat. Just very cool that it all worked out so that we can observe a star so far beyond what we normally can see.
Here is the article talking about it:
https://www.popularmechanics.com/space/deep-space/a19660234/astronomers-gravitational-lensing-spot-a-star-9-billion-light-years-away/
Re: Observing a star from 9 billion light-years away
04/03/2018 9:14 AM
When Einstein first predicted gravitational lensing, he doubted that the exact required alignment would occur.
http://www.einstein-online.info/spotlights/grav_lensing_history.1.html
The Engineer
Good Answers: 129
04/03/2018 9:25 AM
It's just fortunate that there are so many galaxies floating along out there.
04/03/2018 3:13 PM
I'm thinking that at the time Einstein predicted gravitational lensing, our galaxy was thought to be the entire universe and external galaxies were thought to be "nebulae" within our galaxy. Only a few years later, Hubble discovered redshift and proved that the universe was much larger than had been thought.
Einstein was thinking of one star in our galaxy lensing another star. A star's mass is very much less than a galaxy and a lensing event from a star would require a very fortuitous alignment.
https://www.windows2universe.org/the_universe/uts/timeline.html
The Engineer
Good Answers: 129
04/03/2018 3:28 PM
I think you're right. I've occasionally wondered if we could somehow exploit several stars in a row to get a better image of a star system in our own galaxy. The idea being it may be easier to view details about exoplanets in that system. Unfortunately, the star's gravitational lensing may still be too small even in that situation.
04/03/2018 9:48 AM
With the gravitational lens effect there's been a question I've often wondered if anyone has ever attempted to measure.
The graphic from your link provides exactly the image for my question. The top light ray path is longer than the bottom light ray path. In any terrestrial optics this difference in path length is ignored. But with an astronomical size lens this distance difference may be noticeable. Will the light following the lower path exhibit more of a red shift than the top path?
This might be an imperceptible tiny difference, even with an astronomic lens, because the total path length is an even bigger astronomic length. Then again as your link points out, at one time Einstein thought this lens effect would never be noticed at all. Now we have two gravitational lenses aligning in space for us to see even farther.
04/03/2018 2:47 PM
For illustration, the graphic, of course, is far out of scale. A scaled drawing would be impossible to draw that would show the deflection.
If the lensed object is a quasar, its size is small enough that fluctuations can occur on a fairly short time period, and cross-correlation between the images can reveal the difference in travel time.
Here is some actual data:
Table 1. Time Delay Measurements
System
Nim
t (days)
AstrometryModelRef.
HE1104-1805
2161 ± 7+"simple"1
PG1115+080
425 ± 2+"simple"2
SBS1520+530
2130 ± 3+"simple"3
B1600+434
251 ± 2+ / -"simple"4
HE2149-2745
2103 ± 12+"simple"5
RXJ0911+05514146 ± 4+cluster/satellite6
Q0957+561
2417 ± 3+cluster7
B1608+656477 ± 2+ / -satellite8
B0218+357
210.5 ± 0.2-"simple"9
PKS1830-211
226 ± 4-"simple"10
B1422+231
4(8 ± 3)+"simple"11
Nim is the number of images. t is the longest of the measured delays and its 1 error; delays in parenthesis require further confirmation. The "Astrometry" column indicates the quality of the astrometric data for the system: + (good), + / - (some problems), - (serious problems). The "Model" column indicates the type of model needed to interpret the delays. "Simple" lenses can be modeled as a single primary lens galaxy in a perturbing tidal field. More complex models are needed if there is a satellite galaxy inside the Einstein ring ("satellite") of the primary lens galaxy, or if the primary lens belongs to a cluster. References: (1) Ofek & Maoz 2003, also see Gil-Merino, Wistozki, & Wambsganss 2002, Pelt, Refsdal, & Stabell 2002, and Schechter et al. 2002; (2) Barkana 1997, based on Schechter et al. 1997; (3) Burud et al. 2002b; (4) Burud et al. 2000, also Koopmans et al. 2000; (5) Burud et al. 2002a; (6) Hjorth et al. 2002; (7) Kundic et al. 1997, also Schild & Thomson 1997 and Haarsma et al. 1999; (8) Fassnacht et al. 2002; (9) Biggs et al. 1999, also Cohen et al. 2000; (10) Lovell et al. 1998; (11) Patnaik & Narasimha 2001.
https://ned.ipac.caltech.edu/level5/March04/Kochanek/frames.html
The simplest explanation I've seen of redshift is that the light has been stretched by the universal expansion over the time period from when it was emitted to when it was detected. So the difference in redshift can be estimated by the difference in travel time.
The largest value I see from the table above is 417 days, so the difference in redshift would be negligible.
04/04/2018 1:18 PM
"The simplest explanation I've seen of redshift is that the light has been stretched by the universal expansion over the time period from when it was emitted to when it was detected."
Is that simpler than the Doppler effect?
04/04/2018 7:54 PM
My understanding is that there are three types of redshift -- gravitational, doppler, and cosmological. Light emitted from deep in a gravity well will be reddened due to loss of energy "climbing out". Doppler, of course, is due to relative motion between the source and detector. Cosmological redshift is due to the expansion of space itself. Cosmological expansion can permit the distance between two galaxies far apart to increase greater than 3 x 108 m/s.
According to Wiki:
"There is a distinction between a redshift in cosmological context as compared to that witnessed when nearby objects exhibit a local Doppler-effect redshift. Rather than cosmological redshifts being a consequence of the relative velocities that are subject to the laws of special relativity (and thus subject to the rule that no two locally separated objects can have relative velocities with respect to each other faster than the speed of light), the photons instead increase in wavelength and redshift because of a global feature of the spacetime metric through which they are traveling. One interpretation of this effect is the idea that space itself is expanding.[27] Due to the expansion increasing as distances increase, the distance between two remote galaxies can increase at more than 3×108 m/s, but this does not imply that the galaxies move faster than the speed of light at their present location (which is forbidden by Lorentz covariance)"
https://en.wikipedia.org/wiki/Redshift
04/04/2018 12:54 PM
"The top light ray path is longer than the bottom light ray path."
I assume that's an "Oops".
I believe you must be correct about the greater red shift for the longer path, but whether the difference is measurable, I have no idea.
04/04/2018 3:11 PM
It's amazing the various ways lysdexia dyslexia can manifest.
04/04/2018 1:49 PM
Clearly, a telescope would have to be pointed in one direction to have the image formed by the upper path centered in the field of view, and a slightly different direction to have the image formed by the lower path centered in the field of view. If the orientation of the telescope is halfway between those two positions, can both images be seen in a single field of view at the magnification used?
Also, if S is directly centered behind M, as observed from O, then both paths would be the same length, and they would be only two of an infinite number of paths following all sides of M, so it seems to me that S would appear as a continuous ring with M at its center. Is this the "Einstein Ring" referred to somewhere in this blog?
I assume that when S is just slightly off-center, that ring would be brighter on on one side than the other, and that at greater deviation, part of the ring would disappear, so S would appear as an arc. Thus, for S to appear as a single point of light, it would have to be significantly off center. Are my assumptions correct?
Finally, I know that all objects involved are moving through space-time, but I have no knowledge of the apparent speed of motion. In other words, how long does the alignment remain useful? Based on Rixter's data, I gather that st least some of these alignments must last for more than a year.
04/04/2018 4:36 PM
There are all sorts of effects, depending on the strength of the lens and the relationship of the object, lens, and observer, and a description does not do it justice. The point is that instead of acting like a simple magnifying glass, a gravitational lens acts more like the base of a wine glass, where the bending is greatest toward the center and least at the edges.
Go grab a glass of wine, finish the wine, and look through the base. A small object held behind it, depending on its position, may be seen multiple times or magnified into a ring. This is a good model for a gravity lens.
An illustration might help. Here is a simulation of a gravity field and its effect on background objects.
04/04/2018 12:27 AM
Rixter,
how do you differentiate gravitiational lensing from density lensing?
I asked a woman who gave a talk on black holes (her speciality) this question and got an unsatisfactory answer.
I don't know why this effect is never mentioned, but imagine a star floating in space, as they are wont to do, gravity ensures there is a gradient in gas density in some proportion to the gravity but also due to the efflux of matter.
Surely this gradient of matter (both atmospheric and efflux combined) results in a lensing device.
How do you show the gravitational component versus the "matter" component, or dare I ask, does the gravitational component actually exist at all (sorry Einstein) and it is all "matter" lensing instead?
04/04/2018 9:12 AM
That's a very good question. I think the answer is that the spectrums of the light from multiple images of the same object are virtually identical. Refraction caused by matter affects different wavelengths differently. I think you might also see absorption lines in the spectrum (probably hydrogen) if it were refraction rather than gravitational.
Someone else with the same idea:
https://physics.stackexchange.com/questions/7250/gravitational-lensing-or-cloud-refraction
04/03/2018 9:22 AM
So the universe gave us an accidental, extraterrestrial telescope. I wonder what the f number for this telescope would be?
The Engineer
Good Answers: 129
04/03/2018 9:24 AM
Exactly! And good question, I'd like to know too. That would really give us an idea of how hard it is for something like this to happen.
04/03/2018 10:23 AM
f-number is the ratio of a lens diameter to the focal length.
A gravitational lens is much different from an optical lens in that it doesn't focus light the way an optical lens does. The light rays that originate from a point and pass through an optical lens converge to a second point, the focal point. Light rays are deflected less from the center of a gravitational lens than near the center.
So, f-number does not apply to gravitational lenses.
04/03/2018 10:53 AM
Here's a converging lens ray trace and the gravitational lens ray trace from your link.
To me these ray diagrams look similar enough, they both converge, that I don't see why an f number analogy cannot be pondered. While it is true that a gravitational lens has no physical lens edge to measure an aperture there surely must be a measurable optical angle at O and a distance between O and M to make a virtual aperture.
04/03/2018 2:15 PM
Gravity fields make very poor optical lenses.
Here's another way to look at it...
A ray passing near the center of an optical lens is hardly bent at all. Those rays passing through near the edge are bent more, so that all rays converge on the image.
A ray passing near the center of a gravitational lens is bent the maximum amount whereas a ray passing at some distance is bent very little.
http://www.artemis-uk.org/Microlensing_physmath.html
Re: Observing a Star from 9 Billion Lightyears Away
04/03/2018 10:29 AM
that scenario almost sounds like a type of game of chance like a lucky shell game to be able to see it.
Good Answers: 52
04/03/2018 4:24 PM
I have always found the idea of gravitational lensing interesting. Does a gravitational lens work with more than just optical? I only hear it mentioned in relation to the optical spectrum but I would imagine it would lens over all frequencies.
04/03/2018 5:29 PM
Yes, but it is considerably easier at optical wavelengths.
The deflection of gravitational lenses is on the order of an arcsecond. The resolution of a receiver is a ratio of the wavelength to the size of the receiver. To get this resolution with radio waves requires a connected array of radio telescopes connected as an interferometer.
https://www.cfa.harvard.edu/news/su201608
Good Answers: 146
04/03/2018 5:27 PM
Very cool that this happened, but sure makes you think about how much we are missing. The blind men and the elephant comes to mind.
incus opella
04/03/2018 10:08 PM
Here's the original paper. I haven't had time to digest it.
https://www.nature.com/articles/s41550-018-0430-3
04/06/2018 6:37 AM
Lots of replies are very interesting but do not say how the bending of light by gravity makes it possible to see further into space - unless it also acts as a powerful magnifier of everything beyond.
I can understand how something hidden behind a dense object can be bent into view but it would be more or less the same size I guess.
04/06/2018 5:50 PM
Light intensity decreases with the square of the distance. There is a limit to the minimum amount of light we can see. A star at 9 billion lightyears distance, even a giant star, would be too faint to be detectable.
A gravity field bends light and acts like a lens, not a perfect lens like a magnifying glass, but more like the bottom of a wine glass. If the source is in the right place, the gravity lens is in the right place, and the observer is in the right place, more light from the distant source will arrive at the observer making the otherwise invisible object visible.
Register to Reply 26 comments
artsmith (1); Bayes (3); dkwarner (3); frankd20 (1); GJM (1); horace40 (1); phoenix911 (1); redfred (4); Rixter (11)
