Previous in Forum: Do one have to educate in a university if he work in a factory?   Next in Forum: List of obsolete or amalgamated companies
Keel Cooler
09/12/2007 8:49 AM
Does anyone have a calculation sheet for using ss pipe as a keel cooler on a pump stations diesel engine?
Re: Keel Cooler
09/12/2007 8:56 AM
Many narrowboat engines use keel coolers. As with most things, size is important; there was an article in Waterways World magazine a few months back about sizing them.
Re: Keel Cooler
09/12/2007 11:16 AM
You need some heat transfer coefficients don't you? Maybe even have to measure some in appropriate conditions?
Wish I was here more often.
Re: Keel Cooler
09/12/2007 12:29 PM
Will find it for you tomorrow.
Better off using 90/10 Cupro nickel than SS pipe, unless of course you have a specific reason for using SS.
Re: Keel Cooler
09/13/2007 7:24 AM
Morrison pumps design them into the pump body www.morrisonpump.com
Re: Keel Cooler
09/13/2007 8:56 AM
Here is what I have, it's for marine keel coolers but it should work OK for your application:-
Jacket water heat rejection .....................................BTUs/min, kW
Jacket water flow...................................................gpm, l/sec
Vessel speed classification......................................(not required for your engine)
Anticipated max sea water temperature......................F0, C0 or in your case this would be the raw water temperature.
Min cooler area required.............................................ft2/BTU/min, m2/kW
Min area required (line 1 x line 5).................................ft2.m2
Unfortunately I forgot the chart for line 4. Hopefully I can remember it tomorrow when I go to work. Sorry about that.
Re: Keel Cooler
09/14/2007 10:31 AM
Unfortunately, my scanner has decided to throw the claw in, however, if you could forward me the anticipated maximum raw water temperature and your maximum engine kW, I will try and get a figure back to you.
Anonymous Poster (1); MOBI (3); PWSlack (1); Wrenched (1)
