Previous in Forum: What is This?   Next in Forum: Microwave Intensity Meter
11 comments
Air Flow in a Vertical Pipe
04/08/2018 10:39 PM
Does air flow change at different positions in a vertical pipe. I understand it will change due to stack effect, but if there was a fan at the bottom of the pipe and the top is open to atmosphere ( fan sucking air from the top) will the flow rate change at different heights?
Re: Air flow in a Vertical Pipe
04/08/2018 11:27 PM
There would probably be some variation due to turbulence...but the air flow characteristics are different between negative and positive atmospheric pressure and it would be much more pronounced in a positive pressure situation, negative, not so much....
https://www.myodesie.com/wiki/index/returnEntry/id/3006
04/09/2018 12:08 AM
How high is the top of the pipe?
04/09/2018 2:38 AM
Mass flow, no change; volume flow increases as height increases (and pressure decreases).
How does a fan at the bottom of the pipe equate to a fan sucking air from the top? Do you know what the real situation is?
04/09/2018 6:03 AM
Can you characterize the heat flux along the pipe?
Surface roughness?
How about joints and other possible surface disruptions to the pipes interior?
What is the interior diameter as compared to length (height)? Does the fan impart something other than uniform straight flow across the diameter?
It the intake cut square?
If the air calm near the intake?
Re: Air Flow in a Vertical Pipe
04/09/2018 11:00 AM
The mass flow rate would obviously have to be the same. Volume flow rate is related to mass flow rate by density (dV/dt = 1/ρ x dm/dt).
The two factors that determine density are pressure and temperature.
The two factors that determine pressure are the weight of the air and the pressure drop due to the flow. These two factors act in opposite directions.
The first causes a decrease of 0.00053125 psi per foot elevation. The second depends on the square of the flow velocity, the cross-sectional area of the pipe, the length of the pipe, and the characteristics of the inside of the pipe.
So, mass flow is constant, volume flow depends on density variation which depends on pipe dimensions, flow rate, and temperature variations.
04/09/2018 3:38 PM
It would be useful to know the Reynolds Number that applies to this installation.
04/10/2018 9:05 AM
All those effects (surface roughness, turbulence, diameter changes, etc) will affect the actual flow rate. But if there are no entrances and exits along the pipe, the cfm at the bottom must be the cfm at the top. Pipe diameter changes will affect the air velocity, but not the cfm.
Lehman57
Good Answers: 25
04/10/2018 12:19 PM
The SCFM will be the same at top and bottom.
The CFM will be different.
It is an important distinction (See here)
Troy
04/10/2018 1:17 PM
Does this question have any basis in reality? In other words, is it a real life situation* or just theoretical/hypothetical?
*"real life situation" for TINAC
Real-life | Definition of Real-life by Merriam-Webster
04/11/2018 2:36 AM
Oh Lyn. don't feel threatened. Your position as the top real-life one-stop source of curmudgeonry remains unchallenged.
04/11/2018 2:57 AM
Then the others aren't trying hard enough...
Register to Reply 11 comments
Lehman57 (1); lyn (2); PWSlack (2); Rixter (1); SolarEagle (1); Tornado (1); Troy36 (1); truth is not a compromise (2)
