Previous in Forum: What is APDV Technology in Engines?   Next in Forum: Simulation Tool - Simulation of a Circuit To Determine the Speed of Air Pump
Water Line Valves
04/27/2018 12:38 AM
I am in the above industry. I find that most of the standards across the globe specify allowable stresses as 1/3 of YP to 1/5 of UST Many of these are old standards....but many of the valve components are cast. Considering the environmental issues I consider revision of these. Similar efforts on structural use of steel is on and moving rapidly. With rapid acceptance and validation of FEA think we must minimize use of energy guzzling cast iron
Pathfinder Tags: waterline valves
Re: water line valves
04/27/2018 3:57 AM
"Energy guzzelling cast iron"
Could you elaborate?
Here are some estimates of energy required to produce vatious materials. It says nothing of part longevity, which obviously can have a large impact on ongoing cost.
04/27/2018 12:47 PM
This was interesting, I had to check of what was told to me.
  • Aluminum (from 100 % recycled aluminum): 11.35-17MJ (3,150 to 4,750 watt-hours)
  • Aluminum (from a typical mix of 80% virgin and 20% recycled aluminum): 219 MJ (60,800 watt-hours)
  • Aluminum (from bauxite): 227-342MJ (63,000 to 95,000 watt-hours)
What was told to me, that it took more energy to produce aluminum from recycled aluminum that from bauxite.
I'm always had a hard time believing that, but I never check... and now its settled.
04/27/2018 4:41 AM
Comment withdrawn.
Re: Water Line Valves
04/27/2018 8:52 AM
"The wonderful thing about <...standards...> are that there are so many to choose from." - Anonymous Poster #0
If a standard warrants revision then the correct course of action would be to contact the standards control body directly and seek involvement with like-minded peers when the revision date for the standard approaches.
Lobbying/moaning at other CR4 readers would seem an unlikely strategy to yield any result.
<unsubscribes>
04/27/2018 12:40 PM
From TINAC's table, in case you didn't look:
  • Steel (from recycled steel): 6-15MJ (1,665 to 4,170 watt-hours).
  • Iron (from iron ore): 20-25MJ (5,550 to 6,950 watt-hours)
  • Steel (from iron): 20-50MJ (5,550 to 13,900 watt-hours)
04/30/2018 3:36 PM
I had an experience in the Navy with something like this. ASME code was considered too conservative, so an alternate standard similar to what you proposed was tried. The result was that the valve pressure boundary parts deflected under pressure and the valves failed to function due to loss of internal geometric dimensional control.
You are deflection limited for proper function, not pressure boundary limited for pressure boundary integrity.
Register to Reply 6 comments
Jpfalt (1); lyn (1); phoenix911 (1); PWSlack (2); truth is not a compromise (1)
