Previous in Forum: Eastwood Welders   Next in Forum: AI Spontaneously Re-Creates Brain Activity Pattern Used in Navigation
13 comments
Good Answers: 16
Railway Wagons: Bottom-discharge vs Tippler
05/10/2018 7:10 AM
Hi,
Are there any rail lines worldwide that transports heavy minerals (ores) over long distances, say >500 km, in bottom-discharge wagons (called hopper cars in the US), as opposed to box/gondola wagons that will go through a tippler? My query relates to heavy minerals - iron ore, chrome, etc. - NOT coal. I'm doing some work on comparing the pros and cons of the two systems. My usually brilliant internet searching skills are deserting me on this one!
Re: Railway Wagons: Bottom-discharge vs Tippler
05/10/2018 9:17 AM
Yep. The UK does it, among others.
Good Answers: 25
05/10/2018 10:34 AM
In this part of Wisconsin there is a lot of "frac-sand" mining. It is all shipped in hopper bottom cars.
Troy
05/10/2018 11:31 AM
Why not explore the use of combinations of both systems? They could then be used anywhere.
Google: coal unloading from wagons
05/10/2018 12:16 PM
Coal is coming to an end on the railways of the UK anyway.
Good Answers: 181
05/10/2018 4:20 PM
40+ years in quarrying and I’ve never come across anything other than bottom discharge. It’s far quicker and easier for bulk loads.
05/10/2018 4:36 PM
Well, for something new here's some scale models of the ubiquitous "Airfix" 16T mineral wagon. Over 100,000 were built:
The white stripe indicates which end the tipper-end-discharge-door is.
05/11/2018 12:20 AM
If your doing this for a personal project it is one thing,
If your doing this for pay, provide enough information to keep yourself a part of the solution.
I once read an article in model railroader that explained in detail the research you are working on
05/11/2018 8:12 AM
Yes - the question struck me immediately as a question from a model rail fan looking for a non-typical real world situation that would allow his use of the wrong type of car on his layout.
05/11/2018 1:48 AM
I am fairly sure that the Ma'aden Alumina Refinery & Mill used bottom discharge rail cars (it definitely uses rail cars). The rail line runs from the middle of Saudi desert - about 700km in a straight line.
The refinery is just north of Jubail shows up clearly on Google Earth
05/11/2018 8:06 AM
I work at a company that uses both types of unloaders, but for coal.
Good Answers: 16
05/11/2018 9:42 AM
Thanks for all the responses! I'm only peripherally involved in this discussion at work, but remain curious re. things I don't know a lot about... The question on bottom-discharge/hopper vs rotary tippler discharge has quite few facets to consider. (One of the financial/operating considerations would be the capital outlay of cheaper gondola wagons with an expensive tippler, vs the more expensive bottom-discharge wagons with a cheaper off-loading facility, coupled with differences in maintenance costs & outages, wagon length, Gross/Nett ratio, axle loads, etc.)
I have seen enough examples of both systems in the coal world, but for heavier minerals (ores with an SG >2.5, say), tippler systems seem to dominate, even over shorter distances, with very few examples of bottom-discharge wagons over the longer distances sometimes seen in coal. My initial question was posed just to see if I'm missing something obvious. I've looked at some systems in Australia & Brazil to start off with.
(Sorry for being a bit cryptic, but I don't want you to do my work! And there are some sensitive issues that limits my ability to discuss in more detail )
05/11/2018 11:24 AM
The biggest advantage I see to unloading a car by rolling it upside down, is that it is difficult to clog. Draining through a hopper facilitated by a vibrator still requires intervention sometimes.
05/11/2018 11:58 AM
Gideon you may find some interesting information here. Bottom-Discharge.
sishen to saldanha railway line.
The Sishen–Saldanha railway line, also known as the Ore Export Line, is an 861-kilometre-long (535 mi) heavy-haul railway line in South Africa. It connects iron ore mines near Sishen in the Northern Cape with the port at Saldanha Bay in the Western Cape.
Register to Reply 13 comments
gideon (1); lyn (1); Oomborrie (1); Phys (1); PWSlack (3); simonsd (1); tonyhemet (1); TonyS (1); Troy36 (1); XNuke (2)
