Previous in Forum: About ASME BPE Certified Components   Next in Forum: Impulse Turbine
Matched Angular Contact Bearings
05/14/2018 6:41 AM
How to identified matched angular contact bearings ?
i have bearigns with -1 & traingle stamped on innner race , what will be its pair ?
Re: Matched Angular Contact Bearings
05/14/2018 6:51 AM
It sounds as though purchase inventory and materials storage records are not as rigorous as those applied in a well-run facility. After all, having sorted this out, how would one prevent recurrence?
05/14/2018 7:14 AM
Yes our inventory management can be improved,
but for now , how i can match two bearing out of lot ?
any identification Mark ?
05/14/2018 5:15 PM
Easy. Contact the manufacturer directly.
Oh, er, see #3⇓.
05/14/2018 10:23 AM
I would try to get a spec sheet from the manufacturer....
http://www.nsk.com.br/upload/file/NSK_CAT_E1254f_148-151.pdf
05/14/2018 10:40 PM
Here are the markings for SKF
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/angular-contact-ball-bearings/single-row-angular-contact-ball-bearings/designation-system/index.html
05/15/2018 11:34 AM
Matched bearing sets are typically packaged as a set. If separated, you become the proud owner of a collection of no longer matched angular contact bearings.
Good Answers: 58
05/25/2018 3:25 AM
These days, most of the major bearing manufacturers produce "universally matched" angular contact bearings. For SKF the suffixes:
  • CA, CB, CC or G for internal clearance
  • GA, GB or GC for preload
As long as you know what is needed by way of preload or internal clearance then you can use any two with the same suffix and safely assume that they are "matched" - so you don't have to shoot your storeman yet nor do you have to order them in pairs, though it helps.
Register to Reply 7 comments
Jpfalt (1); M Naqash (1); Nitz (1); PWSlack (2); SolarEagle (1); The Prof (1)
