Previous in Forum: Matched Angular Contact Bearings   Next in Forum: A Design Problem
11 comments
Impulse Turbine
05/22/2018 9:13 AM
What is the mechanical efficiency of an impulse turbine?
Re: Impulse Turbine
05/22/2018 9:24 AM
Re: Impulse Turbine
05/24/2018 9:26 AM
Thank you :)
Re: Impulse Turbine
05/22/2018 9:53 AM
..."Some energy is wasted to overcome the friction of bearing and other moving parts. Hence keeping this point in mind, the mechanical efficiency is the ratio of actual work available at the turbine to the energy imparted to the wheel.Jul 7, 2017"...
http://www.aboutmech.com/2015/12/impulse-turbines.html
https://www.turbinesinfo.com/steam-turbine-efficiency/
Re: Impulse Turbine
05/24/2018 9:27 AM
Thank you. I appreciate the info.
Re: Impulse Turbine
05/22/2018 11:15 AM
homework?
Re: Impulse Turbine
05/24/2018 9:30 AM
Just researching, you can see it's homework
Re: Impulse Turbine
05/22/2018 4:37 PM
In an impulse turbine, energy is extracted from a jet of liquid. The energy of a parcel of water m moving at velocity V is E = 1/2 m V2. If water enters the turbine at speed V0 and exits at speed V1, the initial energy, E0 = 1/2 m V02 and final energy, E1 = 1/2 m V12 can be calculated by the above formula.
The efficiency is the portion of this energy that is transferred to the wheel, Eff = (E1 - E0) / E0. So determining the efficiency entails calculating the final velocity, V1, and final energy, E1.
The final velocity is determined by the wheel speed, U. If the wheel is not turning, the water will bounce off at the same speed, the initial velocity and final velocity will be equal, the initial energy and final energy will be equal and the efficiency will be zero. Likewise, if the wheel speed, U, is the same as the water velocity V, the initial and final velocities will be equal, initial and final energies will be equal, and the efficiency will again be zero.
Maximum efficiency occurs when the wheel speed is half the water jet speed. In this case, as seen from the viewpoint of the wheel, the water jet hits the wheel at V/2 and bounces off at V/2 in the opposite direction. From the viewpoint of the jet, water hits the wheel at speed V and exits at speed 0, thus removing all of its kinetic energy. Efficiency is 100%.
For other values of wheel velocity, U, and jet velocity V0 :
The exit velocity, V1 = V0 - U - U = V0 - 2U
Substituting in for values of energy for values of U, V0, and V1 in the efficiency formula:
Eff = (E0 - E1)/E0 = (V02 - (V0-2U)2) / V02
Re: Impulse Turbine
05/24/2018 9:28 AM
This is great information. Thank you.
Re: Impulse Turbine
05/23/2018 4:47 PM
Is this a recently-serviced one that has had its rotating parts slathered with oil, or one that is siezed-up, full of rust and other detritus, and only good for "weighing in"?
"How long is a piece of string (rhetorical question - NNTR)?" - Anonymous Poster #0
It would be wonderful to know what happens when one enters <...What is the mechanical efficiency of an impulse turbine?...> into an internet search engine...
<unsubscribes>
Re: Impulse Turbine
05/24/2018 4:21 AM
Doesn't the manufacturer's literature say?
Re: Impulse Turbine
06/02/2018 6:55 AM
In practical, it is observed that all the energy supplied to the wheel does not come out as the useful work.
Register to Reply 11 comments
ankit3302 (1); Anonymous Poster (1); dimples123 (4); PWSlack (2); Rixter (2); SolarEagle (1)
