Previous in Forum: Impulse Turbine   Next in Forum: Welding of Duct Reducer to Flange
23 comments
A Design Problem
05/23/2018 6:47 AM
Hey everyone, this is my first message here.
I hope i will help and get help in this forum.
My problem is:
There is a motor with a vertical pin that rotates at a 90 degree and there's a pole lying on the floor. I have to use the motor to cause the rod to move linearly and can not turn the motor horizontally.
What is the simplest solution that comes to yours mind? thx!
Re: A Design Problem
05/23/2018 8:13 AM
05/23/2018 8:40 AM
with the information given or lack of,... you could eliminate the second pulley and just use the eccentric on the motor pulley to the pin.
But its been so long since I did school work problem solving
05/23/2018 11:03 AM
This sounds like homework.
"There is a motor with a vertical pin that rotates at a 90 degree.?
What does this really mean?
Is that a pole, or a rod?
Maybe copy the question directly from the source?
05/23/2018 2:05 PM
Rod, Pole or Perch?
Good Answers: 137
05/24/2018 4:05 AM
I didn't understand that either. Is the pin the motor shaft? What rotates at 90 deg relative to what? Does it rotate 90 deg one way and then back?
05/25/2018 4:44 AM
Yes! And badly translated. I even think that he/she has not given us the complete problem! There seem to be gaps.
05/23/2018 2:19 PM
The the key to getting a good answer is asking a good question.
05/23/2018 2:21 PM
what ever happened to the phrase "There's never a stupid question"
05/23/2018 2:26 PM
I don't know that anything happened to it.
Did I imply that the question was "stupid"?
05/23/2018 2:41 PM
Yes,... but here, how's... "There's never a stupid bad question"
05/24/2018 9:47 AM
work for the govt. for 30 yrs and you will hear lots of stupid questions.. lots.
sometimes i wonder how some of these people made it thru college. at times i
want to smack the adviser that turned a blind eye to send them thru.
05/24/2018 10:05 AM
work for the govt. for 30 yrs and you will hear lots of stupid question..... adviser that turned a blind eye to send them thru.
Word has it, it very hard to fire a public servant... I guess its not in the union contract to fire an employee incompetency and what you experienced is the sum of it.
05/24/2018 11:48 AM
You cannot imagine how true that is.
As a wise man once said "you gotta work here to believe it"
05/26/2018 1:53 PM
Wow,... what a coincidence, we were just talking walking about this... The hammer drops....
This won’t make MSM,... and never will.
05/23/2018 4:29 PM
05/24/2018 12:55 AM
Lie on the floor, on your side. Parallel to the motor, the pole to your side, your eyes, at parralax, will place the motor at horizontal. The pin, will move linear, in it's circumference.
Good Answers: 153
05/24/2018 5:21 AM
You must keep the motor vertical but there is no restriction on raising or lowering it. Lower the motor so that the top circumference of the horizontal pin is just above floor level. Wrap a high friction material like rubber round the pin. Place one end of the rod onto the pin and run the motor so that the pin acts as a driven roller moving the rod over it.
05/24/2018 6:06 AM
As long as you're "extracting" the power from the motor by wrapping a cord around the spindle, you can route the "destination" of the power to anywhere with a series of pulleys.
05/24/2018 11:11 AM
A picture (or drawing) is worth a thousand words.
Each of us hoping to help has a different mental image of whatever it is you are attempting to describe, and it is probable than none of those mental images are the same as your own image...
05/30/2018 5:08 AM
are is
05/30/2018 5:50 AM
"none are"
OR
"one is"
05/30/2018 11:31 AM
Thanks to you and to AP#1! You got me to thinking about it... and looking it up.
http://www.latimes.com/tn-gnp-0429-a-word-please-none-is-or-none-are-both-work-story.html
After studying this and looking it up in multiple places, I have concluded that AP#1 is right! The pronoun must agree with the word(s) it replaces. In this case the words it replaces could either be "not one (singular)" or "not any (plural)", but I think the "not one" is a bit more appropriate.
Usage may differ in the UK...
05/24/2018 12:41 PM
Hey Deefburger, are these yours?
Register to Reply 23 comments
Anonymous Poster (1); Codemaster (1); dkwarner (2); jhhassociates (1); JohnDG (1); lyn (3); Mikerho (1); phoenix911 (5); PWSlack (1); Randall (3); setlock77 (2); SolarEagle (1); tonyhemet (1)
