Previous in Forum: Determining Air Cannon Efficiency   Next in Forum: Self-Supported Chimney Design
EN and DIN
09/17/2007 6:27 AM
What is the difference between EN (European Norms) and DIN ?
Re: Standards
09/17/2007 7:01 AM
Nothing much.... the DIN standards are the old German standards similar to our BS standards in the UK. the EN are as you say the European Norms standards that in Europe is the one we all work to, or should!...
John.
Re: Standards
09/17/2007 7:22 AM
Thank you John,
If my understanding is correct DIN standards are no longer used in Germany & in Europe.
I have still some more query.
Whether all the european countries are following these EN norms for all of their projects
Whether EN norms is only the modification of old German standards or it does include the requirements / standards specifed by the other European countries also.
thanks in advance
arbaskaran
Re: Standards
09/17/2007 9:21 AM
<Whether all the european countries are following these EN norms for all of their projects>
It's difficult to ascertain. EN standards are intended to be a common 'language' (for want of a better word) encompassing best practice and pan-European compatibility.
One can deviate from them, of course, and then one is very much on one's own...
Re: Standards
09/17/2007 11:17 AM
Perhaps the below may help!
I presume you understand the background to Article 100a Directive and the European Machinery Directive.
The comments below refer to the standards only.
Having said that, if you, the manufacturer apply the mandatory CE mark to a machine, you are stating that the user can assume compliance to the standards. If you have assumed your own "Standard" is as good as that advised and something goes amiss, you are on your own!
The European Committee for Standardisation (CEN) is mandated by the European
Commission to draft harmonised standards for the purposes of Article 100a Directives
and, if these are used by manufacturers of machinery, will be one of the ways in which
compliance with the EHSR's can be achieved. If a reference to a harmonised standard is published in the Official Journal of the European Communities then its use provides "a presumption of conformity" (rebuttable) of satisfying the EHSRs. If, however, a harmonized CEN standard does not exist, it is still possible for machinery to be certified and CE marked.
"Harmonised standards are not legislation (Note: unless incorporated in the legislation)
and do not replace existing legislation. Subject to the transitional arrangements
machinery first supplied after 1 January 1993 in the UK has to satisfy the requirements of these Regulations assuming that the product is within their scope. Using a harmonized standard is one of the ways of complying with the EHSR addressed by that standard.However, the use of such standards is voluntary. They do, however, replace
British Standards on the same subject."
EHRS's are the Essential Health and Safety Requirements
EHSRs basically set safety requirements to be attained by manufacturers who have
considerable flexibility as to the way in which they meet them. (Unless in Schedule IV of the Machinery Directive).
The description in inverted commas are taken from "Advice to British Industry" issued by the UK Dept of Trade and Industry.
Good Answers: 137
Re: Standards
09/18/2007 4:21 AM
Hello arbaskaran
I'm not familiar with many of them, but not all EN standards are based on DIN. Pipe flanges follow DIN 2526 but pipe threads for example follow British stds, BS 21. It would be nice to think EN incorporate the best bits of various national stds.
Does anybody know whether EN and ISO stds are the same?
There was a BS for testing centrifugal pumps, BS 5316 which I believe was incorporated into ISO 2548. If so it's a pity as in my opinion BS 5316 is a very poor std. I had a discussion with BSI about it some years back but didn't get any sensible answers. Better to base it on American std ANSI/HI 1.6-1994 which is much better (apart from not being metric!)
Codey
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: EN and DIN
09/18/2007 4:14 AM
My understanding of EN numbers when relating to steel was in fact to do with the British Government having to bring in standardisation when building subcomponents of military hardware in many locations during WW2. It originally designated different grades of steel into Emergency Numbers (e.g. 43c). This standard has hung on for a long time but is being fased out for a different system that I can't remember of the top of my head. It would be confusing in my mind to have a new EN standard!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Re: EN and DIN
09/18/2007 12:00 PM
HI,
DEAR SIR,
BY ENLARGE, EN AND DIN ARE SIMILAR BUT NOT THE SAME,AS PER ME IT IS COMBINATION OR AMALGAMATION OF ALL EUROPEAN CONTRIES' STANDARDS SUCH AS 'DIN' GERMAN, 'BS' UK, 'NFE' FRENCH AND SO ON.
I THINK LIKE CURRENCY IS NOW COMMON IN EUROP LIKE WISE INTENSION MUST BE TO HAVE COMMON STANDARD FOR ALL EUROP,IN AL WALKS OF LIFE.
IN CASE OF FLANGES,RAISED FACE HIGHT IS DIFFRANT FROM 2.0MM TO 4.0MM AS PER DIFF.SIZE AND PERSSURE RATING. BUT EN GIVES 2.0 MM FOR ALL SIZES AND RATING.LIKE WISE THERE IS LITTLE DIFFRANCE IN DIN & EN.I FOUND SOME MINOR DIFFRANCESES IN OTHER DIMENSIONS ALSO BUT THOSE ARE SOME TIMES AS PER BS OR OTHER EUROPEAN STDS.
THANK YOU.
V.D.DEODHAR.
Register to Reply 7 comments
arbaskaran (1); Beej50 (1); Codemaster (1); Electroman (1); lighterman (1); PWSlack (1); vidyadhar deodhar (1)
