Previous in Forum: Effect Of Cable Rolling   Next in Forum: electical
11 comments
How to Determine the Number of Revolutions?
09/18/2007 8:32 AM
i have a silvery rotating disc and i want to determine the number of rev.i dont want to make a hole.i want to make a mark with a reflective marker if some exist or have a foil that i could attach to the disc so that i could count that using a sensor.the problem is that i dont know the sensor to use
any help?
if u have done this before,what sensor did u use?
i mean the name and where i can get some to buy
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: number of revolution
09/18/2007 8:53 AM
Remember those old vinyl record turntables? They had a series of reflective bands at intervals around the edge. By adjusting the speed you could get them to synchronise with a given number of AC mains pulses so that the image appeared stationary.
You can see the sort of thing around the lower edge ↑ of this one.
You know the charity shop halfway down Wayne Mayne on the right? There's one in the window if you hurry.
Essex jobs for Essex yobs! <Burp>.
Good Answers: 38
Re: How to Determine the Number of Revolutions?
09/18/2007 9:30 AM
there are a number of infared rpm detectors sold. all you need to do is attach a small reflective strip on the disc. Google RPM sensors.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
09/18/2007 10:24 AM
Whe use a photo optic sensor switch from Sick Optics to read a colored mark on materials. The switching is simple NPN circuitry. This may work for you.
The switch model number is KT5-2N116 and can be found on their website.
Hope this helps.
If necessity is the mother of invention then is laziness the mother of necessity?
09/18/2007 3:29 PM
Hello gdallas,
I use Sanwa make digital non-contact tachometer.
Since you are measuring rpm of silvery disc, i would suggest putting a black tape on a small portion and then stick the reflective strip which comes alongwith the tachometer.
Google the above mentioned bold keywords...may makes are available/
Good luck
He must be very ignorant as he answers all the questions he is asked. Voltaire
09/19/2007 6:15 AM
All of above can solve your problem even you can use proximity switch or sensor for generating pulses and then count, but if RPM is too high then I am afraid, upon addition of any weight at only one place on disc there may be another problem of balance rotation.
09/19/2007 8:27 AM
Depending on what this "silvery" disc is made of you can use a black magic marker line and a strobe light. The marker can then be easily removed with alcohol and a cotton ball.
09/19/2007 10:01 AM
meke 60 hole on your disk use MOC7811 motorola optical sensor measur Frequency of pulsess just with any frequency counter that will be directly RPM
jarun magnet
as pulses are 60 you are measuring in 1 sec i.e. directly prop to RPM
09/19/2007 12:34 PM
You can use the reflective strips from the good old computer magnetic tapes used as tape marker.
Aged man is not old man...
09/19/2007 4:49 PM
United States - Member - New Member Popular Science - Weaponology - New Member
09/21/2007 2:29 AM
You can get a tachometer that works with a strobe light sort of like the timing light for tuning up a car. A small marker with a felt tip will enable you mark the disc withoud damage to check the rpm. Clean off the disc with denatured alcohol.
Men are like steel, if they lose their temper they are worthless.
09/21/2007 8:27 AM
If you do not find one anywhere else, go to a shop that sells stuff for model aircraft...they have such counters for engine RPM, non contact ones too....usually quite cheap.....
Register to Reply 11 comments
Andy Germany (1); Anonymous Poster (1); bhankiii (1); charsley99 (1); chaterpilar (1); double_j_b (1); garyceng (1); jarunmagnet (1); Qqberci (1); Stinky Pete (1); Syed Ziauddin (1)
