Previous in Forum: Best Apps for Engineering Students   Next in Forum: Pump Low Capacity
13 comments
Danfoss Compressor
07/13/2018 2:18 AM
Good day
In the name plate of Danfoss compressor with Model number HCJ090T4LC7 and TECH no. SNH902AF01. What does Tech number stands for?
Re: DANFOSS COMPRESSOR
07/13/2018 2:23 AM
Good Answers: 181
07/13/2018 3:12 AM
Try looking here
07/13/2018 4:57 AM
Danfoss doesn't know either.
Their web site says:
You searched for:
scroll compressor tech numbers
Did you mean
scroll compressor test numbers
07/13/2018 5:54 AM
Thanks
The name plate of a compressor read:
Danfoss Commercial Compressors
Model no HCJ090T4LC7
Tech no SNH902AF01
Serial NO S1714KO3415
I wanted to know if i want to order the compressor is necessary to show Tech no. or the model number only.
Netherlands - Member - New Member Engineering Fields - Mechanical Engineering - New Member
07/13/2018 7:21 AM
If you are going to order one, I guess you could ask your supplier what it means? ;-)
07/13/2018 10:05 AM
To be safe, I'd include it. More information is better than not enough.
07/13/2018 4:09 PM
That depends on what one's actual goal.
Re: Danfoss Compressor
07/14/2018 12:31 AM
Danfoss acquired compressor-maker Scroll Technologies, seen on the internet as Scroll Tech, in 2006. That giant identifier, SNH902AF01, might be Scroll Tech's part number.
07/14/2018 10:46 PM
Wrote to a friend of mine in Danfoss technical. This is his reply.
"As for the question you raised concerning the Danfoss Compressor the information needed to order the correct compressor is the model number HCJ090T4LC7. The Tech number referred to relates to the part number that would have been used by Scroll Technologies who were bought by Danfoss in 2006. I guess that for a while we would have listed both the Danfoss model number and the Scroll Tech number on the label.
From the model number I can identify 2 code numbers 120U2534 is the code number for the “Single Pack” and 120U2531 is the code number for the “Industrial Pack” (12 compressors on a pallet)."
07/16/2018 3:19 AM
One wonders why the Original Poster couldn't have done that him/herself.
07/21/2018 6:06 AM
Thanks
09/27/2018 1:11 AM
What is the difference between Model HCJ090T4LC6 and Model HCJ090T4LC7, Can i use them interchangeably?
09/27/2018 1:29 AM
Or what is the function of threaded oil site glass.
Register to Reply 13 comments
Bo1000 (1); dmtonyole (4); evanmjones (1); lyn (2); PWSlack (2); redfred (1); TdZeeuw (1); TonyS (1)
