Previous in Forum: How Much Hydropneumatic Pressure is Comparable to Hydraulic?   Next in Forum: Chiller Controls
9 comments
Spectacle Blind (Use to Isolate the Line)
09/08/2018 7:21 AM
Is spectacle blind required coating in case of pipeline/ line-pipe is lined?
"Without goals you are like a ship that has set sail with no destination."
Pathfinder Tags: Spectacle Blind
Re: Spectacle Blind (Use to Isolate the Line)
09/08/2018 10:45 AM
Read the specification.
Spectacle Blind - Piping Designer
09/08/2018 11:14 AM
It's advisable to use "best practices" for the materials being used, fluids being pumped, and environmental effects of location...check these links below for further info...
https://www.eng-tips.com/viewthread.cfm?qid=248014
https://plantdesignoperations.wordpress.com/2014/08/05/blinds-in-process-piping/
http://www.piping-designer.com/index.php/disciplines/mechanical/stationary-equipment/pipe-flanges/92-spectacle-blind
09/11/2018 9:52 AM
Find out here.
Good Answers: 34
09/12/2018 9:46 AM
One of the important functions of the spectacle blind or figure eight is to indicate whether the passage of fluid through the pipe is open or closed. The coating must cover the flanges but not the external extension of the spectacle blind. This is relevant in case of fires with smoke in the environment since it allows viewing from a distance if the flow is open or closed
09/12/2018 10:38 AM
Mean that the part of spectacle blind (closed) comes in contact with corrosive fluid is required coating.
Whitephone:The coating must cover the flanges but not the external extension of the spectacle blind.
09/12/2018 10:43 AM
Thanks a lot
Good Answers: 34
09/12/2018 11:04 AM
I never respond to anonymity. The external extension is not in contact with the fluid that extension should not be covered by the coating
09/12/2018 11:16 AM
Yes you're right, we are not going to apply coating over external extension but only at section of Spectacle blind (closed at one side, as shown in Fig.) which comes in contact with corrosive media.
09/13/2018 10:14 PM
How would that hurt anything? (Other than a few cents of budget.)
Register to Reply 9 comments
Adeel Ahmad (2); Anonymous Poster (1); lyn (1); PWSlack (1); SolarEagle (1); Tornado (1); Whitephone (2)
