Previous in Forum: Rated Closed Loop Breaking Current   Next in Forum: Tertiary MVA of Autotransformer
8 comments
Good Answers: 170
Surge Arrestor Blast
10/05/2018 2:33 AM
I have been working in the electrical construction, operation & maintenance field for about 35 years now. I have worked on all voltages from 240V to 420kV. All along my experience, I have never heard of a surge arrestor blast. For me, surge arrestor is such a device, which would act as an insulator until the voltage across it does not increase beyond its rated voltage. And, when the voltage across the surge arrestor goes beyond its rated voltage, the surge arrestor conducts the surge to earth/ground. But, as soon as the surge dies down, the surge arrestor reclaims its insulating properties and becomes an insulator again, ready for the next surge. Isn’t it true?
But, of late, I have been hearing & experiencing quite a lot of surge arrestor blasts, particularly, indoor polymeric surge arrestors, installed in Medium Voltage VCB Switchgear Panels. There is nothing wrong with the selection (viz.) the MCOV, the rated voltage, the nominal discharge current, the rated line discharge class, the rated pressure relief class, etc. The selection is based on manufacturer’s guidelines and on site conditions.
This blast phenomenon is more prevalent in:
i) 33kV Class Switchgear (though there are isolated incidences of SA failures/blasts at 12kV & 24kV)
ii) More so in Solar Photovoltaic Power Plants (At the same voltage level, there are no such failures reported from any other power plants’ or process industries’ installations)
iii) More when the cable length is more, say, of the order of a few kilometres
iv) Initially, there were recurring PT failures, but, later, when the PTs were strengthened with a higher Overvoltage Factor or when the PTs were removed, the Surge Arrestors started failing/blasting.
v) It is unique in VCB Switchgear Panels (At least, I am not aware of such failures with other types of switchgear).
Now, my questions are:
a) What is the reason for such surge arrestor blasts?
b) Why is it predominant only in 33kV Voltage Level?
c) Why is it unique in Solar Power Projects?
d) What has cable length got to do with it?
e) Could the PT failures also be for the same reason?
f) Is this phenomenon unique to switching with VCBs?
g) How to avoid such failures/blasts?
I request your expert opinion on this.
Re: Surge Arrestor Blast
10/05/2018 6:42 AM
10/05/2018 6:49 AM
Surge arrestors we have used - recommended by our compliance consultants - are "once-only" in operation. If they operate to arrest a surge, subsequently powering them on sounds a buzzer to indicate that they must be replaced.
https://www.dehn.co.uk/en-gb/1629/31742/Familie-html/31742/DEHNflex.html
Good Answers: 170
10/05/2018 7:19 AM
But DEHN is manufacturing only Low Voltage Surge Arrestors. My question is on Medium Voltage (3.3kV to 33kV) Surge Arrestors.
10/05/2018 11:25 AM
These types of failures are usually caused by moisture ingress.... has a forensic analysis been performed? I would guess that the failures are related to lack of maintenance and monitoring of the varistor element health of the surge arresters...
http://www.ijoee.org/uploadfile/2013/1006/20131006033843423.pdf
Good Answers: 19
10/06/2018 12:36 AM
I may be wrong, but my thinking goes like this.
Failure occurs due to temperature , due to current flow to the earth.Are we calculating the worst current flow condition and selecting the device to withstand such current?
When i was doing a survey in one of the presiegious installation , i noticed this anamoly and device changed.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 22
10/06/2018 5:40 AM
Is 33kV system isolated type (The source Transformer windings delta connected, for example)!
If true, I have a feeling the long cable capacitance coupled with transformer reactance resulting in resonance. This could be happening if there is a problem in VCB switching (not all poles closing simultaneously).
Other possibility is undetected 1-phase to ground fault in 33kV system, that results in raise of healthy phase voltages which could be as high as L-L voltage.
These over voltages cause PT failures as well as deterioration of SA and subsequent thermal run-away and blast.
The SA, if made to conduct frequently, cause deterioration of ZnO material in the discs which can reduce its insulation value and increase the leakage current. Higher leakage current means higher heat in the SA leading to damage/blast.
Raghunath
10/06/2018 3:55 PM
It <...blasts...> because the surge voltage exceeds its rating.
After a <...blast...>, it's f$£&%ed as a result of the surge.
Simplesζ.
10/07/2018 2:41 PM
Sounds to me like it could be due to induced current due lightning strikes on or near to the site. The solar site by its very structural nature is covering a wide area all connected together with a long cable run, a good potential receiver of lightning (well) potential. You basically have a big antenna.
In regard to your other questions, large scale solar sites are going to be running at a higher voltage to keep the current (and hence cable size and cost) manageable. Yes, PTs are killed by voltage spikes too.
Standard surge arrestors alone may not be enough and you should look into including higher lightning potential grade rated air gap or similar arrestors to help protect against this sort of thing (in addition to the standard surge protectors). Perhaps an air termination system if direct strikes are occurring on or very near the site (like the actual panels or structures in or near the site, eg- security fence, etc).
Register to Reply 8 comments
electricalexpert65 (1); jack of all trades (1); JohnDG (1); JPool (1); PWSlack (1); raghun (1); ramvinod (1); SolarEagle (1)
