My question is about a heat exchanger thats a shell and tube type. It has 130 tubes and they make four passes and its about 16 feet long and 3 feet in diameter. Its used to condense superheated steam at 5 psi and 375 F and heat up water. The water is suppose to be heated from 110 F to 180 F, but its usually only heats up to 140 F. Steam is coming through both sides at the top and condenses at the bottom and the water comes through the bottom and goes through the tubes and out the top. Now the tube bundle just fits in the shell so there isn't a lot of extra space inside the shell for natural condensing that I can tell. Now I know that superheated steam is not very practical for heat exchangers because its heat transfer coefficient is poor and its hard on the equipment from the heat when the steam is going through the tubes. But i was wondering how bad the super heated steam was for this application since its just going through the shell and condensing. Our tube bundles get cracks in them also, brass and stainless steal bundles both got ruined so far over about an 8 year period each. I'm assuming this is from the steam, but I'm not sure, no one that works here knows either and they are just ordering a new stainless steel bundle of tubes. I suggested to de-superheat the steam before it goes into the heat exchanger with spray nozzles or whichever method, but my boss doesn't think its worth it. I just wanted some suggestions on this situation as what is best to do.
